Question about Microwave Ovens
Microwave stopped heating!!
Hi I have a GE microwave jvm1533wd. it stopped rotating and also stopped heating all of a sudden. is there a fuse or something that I can check before throwing it away? Thanks
  • Microwave Ovens Master
  • 9,098 Answers
This should be an easy fix.
This is usually caused by either a bad door switch or a loose door switch mount.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Dec 08, 2008
  • n0junk Aug 03, 2011
    I have a sharp microwave. I saw three switches and tested all three with the door closed using an Ohms meter. The first to showed zero ohms, but the third showed ~15 ohms. I pulled off the connected created a quick jumper using a wire. I turned it on and ran it for 2 seconds confirming it was the switch. I am buying a new d3v-16G-3c25 today!
    Thanks MicrowaveSvc
Cookworks signature microwave oven model:AC821AHT suddenly stop heating .,light comes on , plate rotates but does not heat anything.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 26, 2011 | Emerson Black Microwave Oven
My ge spacemaker microwave oven stopped heating. light still comes on and tray rotates but it does not heat.
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave does not heat..after reading everything about the magnetron my one question is this an easy job that an ammature can tackle or do I really need to call in a service man?
I'm having the same problem with my microwave -- GE JVM1533WD 002.
The inside light, cooling fan and turntable are all working but it is no longer heating food when the Start button is hit.
The unit is noticeably louder than normal, too.
Any suggestions? Thanks in advance for your help.
Jun 09, 2009 | GE JE1660 Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave run with a different noise and stopped heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fkj
Turntable sometimes works, mostly doesn't
It sounds like you have a jamming turntable motor.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 28, 2009 | Microwave Ovens
Microwave does not heat
un plug remove cover find red lead to magnetron with thick long plastic round blob this contains a long glass metal ended fuse that has probably blown due to running when empty long fuse is necessary to stop hi voltage flashing over airgap when fuse blows when fuse blown no output from magnetron as hi volts missing steve t
Dec 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker microwave stopped heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
202 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
