Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Replacement Lamp Hitachi 50V500
I have replaced the lamp in my TV and the green light is still blinking and still no picture
  • 2 more comments
  • lelu1 Oct 08, 2008
    I replaced the lamp in my Hitachi 50v500 and the tv works for a short period of time and then shuts down. The first stage is the Temp indicator flashes. When you proceed to power up the TV the Lamp indicator activates and flashes. Not sure what the issue is anymore.
    Any advice is appreciated.
  • Anonymous Jan 02, 2009
    where to buy a lamp for hitachi 50v500a? thanks
  • bj7mmmag Jan 04, 2009
    i have a hitacht lcd tv model 50vs69a and cant get any chanels
  • Anonymous Mar 26, 2014
    green psychedelic patterns
I opened the back of the TV and sure enough, the micro switch that the lamp ,when in place, was supposed to touch the blue connector to make the connection - they were not touching so I used some sticky tape to build it up to see if it solved the problem and it did !
Posted on Apr 19, 2008
    President:
  • 1,284 Answers
It must be a red light flashing as the 50V500 has no green lights on it. Make sure that when you place the lamp cover back on that it is activting the micro switch behind it. Otherwise the set will assume the door is open and won't ignite the lamp. Otherwise the ballast could be the issue.
Posted on Feb 02, 2007
I have hitachi 50v500 my screen went black and the lamp light comes on by the power button
Lamp light ON means TV needs new lamp as existing lamp is either broken or dead.
Replace lamp in TV, replacement procedure would be written in user manual.
Let me know if you have additional question.
Thanks.
Jan 08, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500
Sounds like the lamp has gone or the filter needs cleaning.
Aug 21, 2009 | Hitachi UX21511 Projector Lamp for 50V500
Temp light and lamp light are blinking. TV is picture is black
Sounds like a 50v500 with a bad light engine, first check the lamp , pull the front cover off remove the lamp door screw , two screws hold the lamp in, see if the lamp is popped. if its good, the light engine is bad cost about $500-$800
hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 20, 2009 | Hitachi Televison & Video
Hitachi 50v500 turns off, then back on.
shanerickp, how many flashes before the picture comes back? that could be your code for a lamp replacement. check your owners manual for that.
Jul 30, 2009 | Hitachi Televison & Video
Bulb burnt out and was replaced but lamp lite still blinks and no
You have one of the following issues.Be sure to check that the lamp door is properly attached. This can cause the the lamp light to go on.
1. Bad thermal sensor for the lamp.
2. Bad ballast.
3. bad supply voltage from power supply.
Apr 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Feb 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Lamp replaced but lite still blinks
I always go to Hitachi first to research...www.HitachiServiceUSA.com..........................T.
Nov 24, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
771 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
