Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Epson RX600 My LCD display is black, unable to view menu on screen. Anybody have a solution? Thanks
  • 6 more comments
  • Anonymous Nov 26, 2007
    The LCD window does not light up.
    Does it need a new bulb?
    How can I replace it?
    Thanks
    Ann
    agoocher@cebridge.net
  • stealthy Dec 13, 2007
    The display is dark. How to repair or replace??
  • BEEZDAD Dec 29, 2007
    LCD SCREEN IS BLANK. CAN NOT CHANGE MODES ON PRINTER.
    ITIS STUCK IN COPY MODE PRINTER APPEARS TO BE DEAD
  • Anonymous Jul 26, 2008
    Same problem. I've browsed the net and seems to be very common.
  • Anonymous Oct 06, 2008
    I just had the same happen to my 2 year old epson and the soldering the fuse sorted the problem. Thanks to the person posted the fix.
  • jamyghys Feb 25, 2009
    Thanks to all of you !! Had the same problem with the LCD-screen, but now it is fixed with instructions I readed here !! After 10 min. of work my screen came back to live. Thanks again for these instructions !!!
  • Anonymous Mar 28, 2009
    Epson Photo RX600 printer. Printer working fine but LCD screen not lighting up so menu and options can be visually selected. Any solutions?
  • gailschuler3 Apr 27, 2009
    screen won't light
  • 23 Answers
Black LCD continued. In fact, the Epson Stylus Photo RX600 appears to be notorious for the LCD burning out! If you go to the Epson Website, they list 3 parts dealers (in February 2007). 2 of 3 of them do not appear to list the LCD screen for replacement. The website of the 3rd one is down. I may call them on Monday. MEANWHILE-- Sooner or later you will want to change your ink cartridges. Here's how to get the cartridge holder to move: 1) Turn off the printer, then turn it on again. Wait until the lights stop blinking. 2) Press the [Setup] button. It should light up. 3) Press the DOWN ARROW 4 times (It is the down part of the concave circular button immediately to the right of the burned out screen). 4) Press the [OK] button TWO TIMES. If you are successful, the printer should buzz briefly. When you open the top, the ink holder should have moved to its "load/reload" position, and you can then change the ink cartridges. Other things to try: After unplugging the printer, I was able to remove the LCD screen with an assortment of flat head screwdrivers and phillips head screwdrivers. The LCD screen itself is in a metal holder, and plugs into a small circuit board, so it could be replaced if any of us can find a new one. It may also be possible to buy a surplus compatible LCD screen, and just plug it in. If it works, the new screen could be taped to the front of the printer, even if it doesn't fit into the manufacturer's hole... Some of you (who have the same mixture of tool skills, boldness, and stupidity as me!) will have the tools and the know-how to remove the dead screen. See if you can find it at an electronics parts supplier The serial number in mine was 0396563 -- If you can find a replacement, post who, where, how much and what. If you don't have the skills or the tools, don't try it. There is too much delicate stuff that can easily be broken on the way in... Just get another one-- Or maybe a Hewlett Packard next time around :-)
Posted on Feb 19, 2007
Found this fix (for FREE) on a thread of people who have had their LCDs go blank (include me in this number). Here is the thread address http://www.fixyourownprinter.com/forums/printer/30847 Steps I took ? and it worked beautifully ? display problem solved !! 1. Ease off the plastic facia that covers the control buttons ? (no screws ? it just clips on) 2. Remove the cross head screw that is seen to the bottom left of the display unit. 3. Flip display unit open ? remove the cross head screw that holds the dark plastic support clip that is behind the unit and top right ish!! 4. Remove the display unit ? unscrew the 4 small cross head screws that hold the display assembly together ? NOTE THAT THE CONNECTING RIBBON RUNS THROUGH THE HOLE ? I didn?t make a note at first, and it took me ages to work out where it went when trying to re-assemble it !! 5. Mark the connecting ribbon so that you know which way up it should be, then carefully pull it away from the black connecting block ? Re-assemble merely by pushing it carefully back into place. 6. On the circuit board you will see a large (ish) black Integrated Circuit ? using a magnifying glass you will see a tiny soldered fuse marked F1 just to one end of this Integrated Circuit. 7. Using a single strand of clean copper wire ( a single strand taken from a multi strand piece of speaker wire is ideal) carefully solder it across the two terminals 8. Having a soldering tip small enough is vital if you are to attempt this ? an ordinary tip is TOO BIG. I used a piece of copper earth wire (obtained from ordinary ?Twin and Earth? electricians household mains wiring cable) I then wound it around my soldering tip and filled it down to a fine point. 9. Re-assemble ? switch on ? and if you have been careful and succeeded in this feat of micro soldering ? you should have a realistic chance of having a fully functioning display once again.
Posted on Jun 23, 2007
  • Janio Apr 10, 2011
    Works!!!! Unbelievable! Thx a lot!
  • John
    John Jul 21, 2014
    Just tried this and this worked. Though I put a dot of solder on the fuse.
    Problem Solver:
  • 12 Answers
Please follow the steps below to resolve your issue.
1. Turn off the printer.
2. Lift the scanner cover.
3. Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
the lock could be located on the left side of the scanner glass
if you were facing the front of the unit
4. Turn on the printer, and the error should be cleared.
Posted on May 09, 2008
  • perdiguerra May 09, 2008
    The lock could be located on the left side of the scanner glass if you were facing the front of the unit.
    4. Then lastly, turn on the printer, and the error should be cleared.
    good luck!!!!
I soldered a wire across F and my display is working fine now.
Thanks for the info everone.
Posted on Sep 14, 2008
Solution #5 worked a treat. I tried micro-soldering but it was beyond me so a blob of solder was deposited across the F terminals and I re-assembled ..... it works!!! Many thanks for sharing that.
Posted on Aug 07, 2008
Solution # 2 or # 5 will work
Posted on Jun 30, 2008
Hello
I just apply solution #2 and it worked . 10 minutes of work !
but the fuse was only maked as "F"
Many thanks
Posted on Feb 20, 2008
Hi, I found this forum while searching for help for my burned out LCD on my epson RX600. I have a solution that actually worked 100% for me. After I left this site I found an ebay auction the guys ebay ID is ice*cube. He sells a set of fix it instructions for 7.99 no shipping because you download them. All you have to do is either replace a fuse with a small piece of wire or put one little tiny blob of solder in place to by pass the fuse (I choose the second option). My printer is now function 100% again. Thanks Theresa
Posted on Mar 21, 2007
My LCD display went black also. I can think of two possible reasons for a black display-- 1) The display is burned out. Comment: This is unlikely, since LCD's have a very long life. 2) The display has somehow gotten disconnected. Comment: More likely. The Epson Stylus RX600 has moving parts inside that could possibly jerk a wire loose or rub through it. My printer is past warranty, so opening the case will not void anything I was likely to get from the manufacturer or dealer. I plan to open it up, find and trace the wiring back, and look for any obvious damage or looseness. If that doesn't work, I will see if I can figure out how to replace the LCD screen. Then I'll see if I can get a replacement part from the manufacturer.
Posted on Feb 18, 2007
I just changed ink printed two page now scanner occrred see user guide can you help?
Posted on Feb 03, 2007
The menu screen does not work and I can not use any of the options because I dont remember how with out the screen. Is it fixable? Should I just buy another printer
Hi!
Seems that the LCD screen of the printer is malfunctioning. Honestly it will be best if you will purchase a new one. One way to resolve the issue is by sending it to an Authorized Service Center in which may cause more.
Hope this helps. Cheers!
Jan 12, 2011 | Epson Stylus Photo RX600 All-In-One InkJet...
The LCD display is black on my EPSON RX600 printer . I am unable to view menu on screen. How do i change the ink cartridges?? Do I need a neww bulb?
If you epson rx600 is installed on your computer, print from the Smart Panel. You can install drivers and programming by connecting it to your computer and letting the "found new hardware" wizard do it's job.
A bubble will pop up to let you know when you are low on or out of ink. Click on the bubble for more information and follow the instructions.
Jul 10, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
My lcd on my printer is not working Espson Stylist RX600
You can call an epson certified servicer near to your area to get an estimate on the cost of repair.
To locate the servicers near to your area, please log on to support.epson.com. Click on Help me find a service center to the bottom right of the page. You have to type in your zip code.
May 13, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
The RX600 does not print anymore. The screen on
This message indicates that your waste ink pads are full and require replacing. Replacement is costly, messy and requires the printer to be taken completely apart. Most often the counter has "jumped" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Apr 01, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
PC monitor is black unable to view
Most probably your LCD screen has got spoiled and the liquid has leaked making the screen blank. Remember our old calculators, how its display changed colors(black) when pressure was applied on it?.....sodeep
Mar 19, 2009 | Dell Latitude X300 Notebook
Epson photo rx600
If the LED display screen on your printer is blank please try disconnecting
the USB cable from the computer and then disconnect the power to your
printer. Reconnect the power to a different power outlet, and turn your
printer back on. If the same issue occurs, your printer will require
service.
Dec 04, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Rx600
Here is a link to the Epson printer RX600 support page which has downloads of latest printer drivers for your unit.
Did you remove any type of protective material that may be on the cartridge before installation?
Apr 26, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Service required
I seem to have fixed my own question. Thanks to the "silly girl" pressing buttons. On the Epson Stylus Photo RX600 try pressing the stop button, color button, B&W button and the On button all at the same time. It starts up without that fatal red indicator with a message saying the ink tray has been emptied. Press the OK button and things are back to normal, I hope!
Dec 01, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Warning Msg. Parts are reaching end of service life. Contact a dealer.
Ink pads on these are cheap to buy but are pain to get to, you would need to have it done for you, I charge 100 bucks a hour as do my peers, pads are abot 30 bucks for the seven of them, plus you have display fault to consider... Replace
Black Display - Copy mode fast
Chgeck out the full reference manual on the CD disk.
Jul 03, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
2,429 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
