Fisher ca 9025 amplifier
Stereo is about 12 to 13 years old and always worked great. then one day went to turn it on by the remote and nothing happend. i checked all the wires and everything was hooked up properly turned off main power and unplugged to try to reset the amp the only light that was on was the red standby light nothing happend. so i took it apart and found one fuse it looked like it was intact but at the end of the cap it had a slight bubble i didn't no if that could cause the problem of not turning on or what this may be this system kicks and has clear music id hate to throw it out or spend a lot of cash to fix it what do you think the problem could be mine is in standby. If I hold the tuner button for anout 10 sec when I release button a relay clicks and unit powers up for about 8 sec then relay clicks off and back to stand mode and this happens with all components unhooked from amp
  • blueyedblksh Dec 06, 2008
    yes it helped.Made me realize it was something I would let a professional repair.thanks
  • 4,234 Answers
The amp is in protect mode. Something in the final stage is defective. This is usually caused by shorted output transistors. This unit is worth getting repaired. Expect a parts cost in the $25-$50 range.
Dan
Posted on Dec 03, 2008
1994 toyota Camry stalls intermittently
Check out the coils, if possible replace with used ones.
Dec 22, 2013 | Worldwide 1994 Toyota Camry DX 2.2L...
Seems to be a complete electrical failure
Always start at least 80% of all vehicle checking with
the battery first
Never go by how many years or miles are on something
If some module failed to time out, your battery goes dead in,
as you said, about 3 days & check if you left the interior lights on
Dec 09, 2012 | Cars & Trucks
Just quit. Worked fine one day. Next day went to turn it on and nothing happened. Fan is little over a year old.
Control switch, circuit breaker, or loose wire are main suspect.
Rarely does a motor just stop working.
Check circuit breaker.
Open control switch and test for power and check for loose connections.
Install ordinary on-off switch and see if function resumes.
Check wire connections at fan.
Jul 11, 2011 | Air King 9166 20" Whole-House Window Fan
1991 Toyota SR5 won't start when the weather is very hot
I checked the gages of the wiring which went into the battery, as suggested by another person on the site, but nothing looked out of place. I then proceeded to check wiring connections throughout the vehicle and found there were 2 sets of wires on the driver's side which were not attached to its counterpart. I remember the mechanics disconnecting those a few years ago, as they stated it was causing the problem. I decided to re-establish the connection for both sets of wires and the truck started immediately with out any further problems.
Jul 09, 2009 | 1991 Toyota Pickup
Logitech 890 remote quit working
It just started working again. Maybe it took the day off.
Jan 11, 2009 | Logitech Harmony 890 Universal Remote
Clarion DXZ655MP Speakers worked then stopped...
sounds like the ohm load of your speakers is incorrect and overloaded the amp,....check all your specs, i.e. max, min ohm load on stereo, and speakers,...this stuff is important and must be within the range allowed or stuff like your experiencing happens,.....it's happened to me before,.....fried my amp because i had house speakers in my van, was great for about 3 loud days,....good luck, cracklin joe,.......
Sep 26, 2007 | Clarion DXZ655MP CD Player
For those who accidently put thier CA-9025 in standby mode by hitting the timer button and no longer have the remote, I figured out how to turn them back on.
Turn on the power button and press and hold the Tuner button for at least 10 seconds. it should come back on :) Hope that helps.
May 08, 2007 | Fisher RS920
Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Dec 14, 2006 | Sony CDX-CA900X CD Player
No sound or picture
Keith, Check fuses Then Resoder The COMPLETE board I bet there is heat related problem W/Old Soder Just a Hunch!!!!!!!! G'Luck Chance One 559 @ Yahoo . Com
Oct 24, 2006 | Toshiba TP55G60 55" Rear Projection...
526 people viewed this question
 Grubhead
Grubhead
