Cd/Dvd burner stopped working on my laptop
I have a Cd/Dvd burner built in on my laptop and I went to burn a cd and it said no device detected. It has always worked in the past, on my old desktop I pressed F5 to check for cd burner. my new laptop does not have it. how do I reset it and fix it? i've tried the solutions you gave, but my laptop is still detecting my cd rw/dvd as cd rom i cannot burn nothing at all
my burner stop working,say's connect to a burner
  • 5 more comments
  • fitler36 Dec 03, 2008
    got it fix thanks
  • Anonymous Dec 18, 2008
    I have a HP Pavilion dv6000, and when I go to burn my cd's it will go through the whole process as if it was burning. Then once its done theres no data on the disc.
  • swagmansbill Jan 28, 2009
    My PB easynoteMV reads dvd but stops burning copy after a short while and flags up 'problem occured writing to disc' and kicks it out!
    Using DVD+R blank discs.
    It also only manages to read mini discs infrequently....hardware problem?..have tried lense cleaner etc Laptop 18months old.
  • Anonymous Feb 01, 2009
    cd dvd burner stoped working
  • Prakashvit Mar 23, 2009
    My DVD drive not detecting in mu presario V3700 laptop
  • Anonymous Mar 24, 2009
    when i try to burn a cd it says to connect to a burner!!!
    help me~~
  • EvilJoe May 11, 2010
    Have you burned CDs on it before? If so how long ago? Have you added any new programs since it worked? Many burning programs don't work well when installed on the same PC. If you are running winXP there are some permission issues that can cause this, otherwise your burner may have died, if you put in a disc with info on it, does it read the disc or time out trying to? Most of the drives I couldn't get to work didn't read or write.
2 Suggested Answers
cpenzes
  • 1102 Answers
SOURCE: Cd/Dvd burner stopped working on my laptop
First you'll want to check on your burning program and make sure the proper cd/dvd burner is checked if your burner offers that option.
What burning program do you use.If all seems well then try these steps.----------------
Right click my computer and then properties
Click on hardware then devices make sure your device is showing.If showing update your driver.
If it is not showing you'll need to go to add new hardware and add this device again.
Let me know how it works out.
They may be other solutions to try.
Posted on Jan 12, 2009
I went to burn a cd and it says my burner or software is not found
Remove the device in device manager and re-boot the computer and let it detect and install the drivers again. This usually fixes the problem unless the drive itself is bad.
Sep 29, 2010 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Dvd RW Burner stopped working after only having it for a year
Check whether the CD/DVD drive has been detected/recognised in device manager. Also check the device status in device manager. Try to install the latest drivers for CD/DVD drive will solve your problem.
Dec 15, 2009 | Gateway (1531356) DVD±RW Burner
CD/DVD burner stopped working
I had the same problem on my Sony Vaio and I found a free program called "CD Tray Pal" You just click on the desktop icon and it loads and windows recognizes your drive. Amazing, after a while, it fixed itself and I did not have to use it anymore! Hope this helps. http://www.e-systems.ro/ You should be able to find it on this site.
Jun 06, 2009 | Dell Inspiron 1000 Notebook
CD / DVD burner
i think it's an hardware problem it might some cable problems try to replace the cable
Aug 08, 2008 | Acer Aspire 5100 Notebook
when i try to burn discs i get message connect burner, my laptop is compatible to do all this
Aug 03, 2008 | Dell Inspiron 1000 Notebook
It could be that the burner has gone out in the drive, this is a common problem. Before you go and replace the drive, it could just be a simple driver glitch, try uninstalling the drivers for the CD drive from the device manager, then reboot. The machine will find the drive and reinstall the drivers. If this doesn't work then you can replace the drive.
Jul 08, 2008 | Acer Aspire 9300 Notebook
Slimline DVD Burner
Go to the device manager. uninstall the dvd drive .restart computer after turning the power off. re-install the device from add hardware wizard.restart computer.this may solve the problem.
Jul 08, 2008 | Computers & Internet
Check the bios when the laptop first boots. There should be a message saying something like "Press F2 To Enter Setup"
See if your drive is detected and listed in the bios.
If not, power off, pop the drive out and reinsert it then try again.
You may have to turn the laptop over and remove one screw about 5" from the edge but near the drive. It will not be in any panel. If you can't see it then a quick read of your manual should show you how it comes out.
If it is detected in the bios, then boot Windows again and go into System then Device Properties (you can reach SYSTEM from control panel)
Check the list to make sure your drive is installed under Windows.
If that does not help, then post back and we can try a few other things.
Apr 11, 2008 | Acer Aspire 5100 Notebook
DVD writable media not recognized by drive... shows up as "Blank CD"
lol a blank DVD cant be opened directly in Win xp, you need to use a DVD burning tool... for your laptop did you check you the DVD-ram reads cd's also?
Feb 03, 2008 | LG GSA-H22N DVD±RW Dual Layer Burner
Cd burner not detected in new laptop
well download nero from download.com see if it works ,oderwise go for repair
Jan 31, 2008 | Computers & Internet
Computers & Internet Logo
1,536 people viewed this question
David Payne
David Payne
