Question about Microwave Ovens
How do you replace the ligth bulb in the GE Microwave Oven JE1590sh01
  • Microwave Ovens Master
  • 9,098 Answers
On this model, you need to remove the outside cover, then you'll see the bulb on the right side, mounted in an air duct.
Please unplug it before taking it apart.
If your model has anti-tamper screws, you can remove them using using a T20H Torx type or GTXH20-100 screwdriver. If the correct tool is not available, there are several ways to remove the screws:
- Use a hammer and a small punch or similar tool to knock out the middle post of the screw, then use a standard T20 Torx bit to remove the screws. (Use safety glasses).
- Insert a small flat-bladed screwdriver (such as a jeweler’s type) into the slot between the post and the edge, tap the screwdriver firmly with a hammer to loosen the screw, grip the screwdriver with pliers, and remove the screw.
- Use a hacksaw or Dremel tool to cut a slot in the head of the screw, then use a flat-bladed screwdriver to remove the screws. (Use safety glasses).
This is a bulb assembly with the socket included. It does not unscrew.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 08, 2008
Change bulb inside ge pvm1870Sm2SS
You can download GE owner's manuals and installation instructions
here.
The manual will cover bulb replacement.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 17, 2012 | General Electric PVM1870SMSS Microwave...
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
Replace the burned-out
bulb with a 40-watt
incandescent bulb
(WB36X10003), available
from your GE supplier.
1 To replace the bulb(s),
first disconnect the power
at the main fuse or circuit
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
removing. After breaking
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
Connect electrical power
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Jan 13, 2010 | GE JE1590 Convection / Microwave Oven
HOW DO YOU REPLACE THE LIGHT BULB IN A GE 1540 MICROWAVE?
1) unplug unit and remove microwave cover (phillips on 3 sides)
2) unscrew white funnel shaped plastic part near back of control panel
3) remove specialty bulb and disconnect leads
4) look for T170 bulb replacement (eBay has them) or roll your own 25W bulb solution
Nov 11, 2009 | GE JE1540 Microwave Oven
Change light bulb in microwave GE Profile JE1590sh01 ?? Where is it located?
Please do not attempt to repair your m/wave, taking the cover off to find the lamp unit is very dangerous, their is still electrical charge in the unit even when its turned off, plesae take it to an approved engineer.
Oct 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How do you replace a light bulb in a GE microwave oven model no.Jes1451BJ02?
The first step is to unplug the oven before changing bulbs.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
If that doesn't answer it, please reply back.
Aug 20, 2008 | GE Microwave Ovens
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
256 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
