Question about Yamaha HTR-6130 Receiver
Set up Can get the radio, but can't get it to work for my TV. I have a Dish.
    Scholar:
  • 107 Answers
Did you mean to get sound from TV run through the Yamaha or the Yamaha run through TV
To get sound from your TV you need audio output at the back of your TV it call MONITOR OUT inclu Video and audio out usualy in RCA connector 1yellow 1 red 1 white use audio out R and L hook up to your Yamaha TV input same colour from TV and select on Yamaha TV mode you should get sound now
Let me know how do you go with that or give me the model and make of your TV
Cheers
Posted on Dec 03, 2008
Codes for tv remote for dish
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Dish TV remote control code list is given.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 16, 2014 | DISH Network Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
What is the manufacturers code to program the tv to dish network? No one is standing by the phones; we have called the numbers given and set up the tv. It works but we would like to set up dish network on...
Hi my nameis Mike Houston of DISH Network and I was going over your post and see you wantto set the DISH Network up to the TV. If you want the code to have the DISHremote to work the TV we have a Power Scan that finds the code for your TV tothe remote, I will send a link to help with these steps. http://www.dishnetwork.com/SupportSection/power-scan-instructions.If you have any questions please e-mail me at Michael.houston@dishnetwork.com.
May 09, 2011 | Supersonic SC-191 LCD TV
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
Lg lht854 does not work tv sound
Ok your dish network wont play through the LHT854? Which Dish network receiver do you have 211, 311, 625, 612, 722? From the owners manuel for the LHT854 it looks like you can only hook up the audio from another source by an optical cable, so how is the LHT854 hooked up to the dish network receiver?
Aug 19, 2009 | LG LHT854 Theater System
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
Jul 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SETUP RCA F38310 TO DISH NETWORK
using your Dish Network box connect the audio and video outputs to the tv via the RCA inputs1, 2, 3, or component inputs on the tv and then select the coresponding video input to view your cable. Or you can connect your Sattelite to the antenna A or B input jack on the back of the set and set the tv input to antenna
Apr 14, 2009 | RCA F38310 38" TV
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Nov 23, 2008 | DISH Network IR Remote Control
Yamaha HTR-6130 Receiver Logo
127 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
