Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Problem with picture
I have a 2 yr old sony and today when i turned it on the color on all four corners looks like a rainbow. Does any one know what might cause this?
  • Bill Cole Feb 03, 2007
    Thanks for the reply. yes is did hear the HUMMM when i turn the tv on. the problem over the last 2 days is coming and going. any other thoughts?
    President:
  • 1,284 Answers
Did you hear the familar HUMMM when you turned on the TV? This hum is the internal degauser and if it's not comming on then there is your problem. On most TV brands you can use an external degauser ring o take care of the issue until repaired but, DO NOT do this on a Sony as it will actully damage the CRT.
Posted on Feb 02, 2007
  • Don
    Don Feb 03, 2007
    It could be a fault in the degausing circuit or do you possibly have speakers that you recently put near the set that aren't magnetically shielded? Or did you possibly move the set to a different location or angle?
Rainbow colors from bottom of screen to top corners
Check its degaussin posistor. Replace it. This component can be located at the main power regulator section.
Picture of the suspected component attached.
May 23, 2012 | RCA TruFlat 27F520T 27" TV
Rainbow screen, no color, tv fell over
ur tv needs to be degaused using a degausing wand or ring. mos def needs to be taken to a professional to be done.
May 18, 2009 | Zenith SY2765S TV
Rainbow colors in top corners of tv
Hi
in this issue you have defective crystal color carrier or you have defective Jungle IC. But the best is to diagnose first.
Thanks!
Jan 14, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture Falling with arch
It is your convergence IC's going out, they cost about 40 $ for both, if you know someone that can solder, i would have them do it, once you see the new parts it is prity easy to find them on the board in your tv, repair shops usually charge 4 to 5 hundred
Jan 08, 2009 | Sony KP-46WT500 46" Rear Projection...
The picture on my 2 yr old Toshiba 42hm66 DLP tv starts flickering and with alot of rainbow looking distortion after an hour of veiwing. I replaced the lamp, but it sill has the probelm. Any idea what...
I hope this helps you but you might wanna look into some other posts too cause it goes farther then the lamps and color wheels. Basically it's a bad product and the consumer should be fixing it. But your problem seems to be the color wheel. Or just a good cleaning. We replaced the lamb in ours and still had a color problem. We're gonna do an exstensive cleaning and dusting of our unit and if it don't work. We're going straight to the manufactor. This is enough with this product! It's costly to repair and still don't have the quality picture it should. It's more then a simple fix and too costly for ppl to just fix and move on. For how old these products are this all should not be happening.
Dec 02, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Printing RAINBOW of colors!
Change the color cartridge and see what happens.
Aug 06, 2008 | HP Deskjet 6940 InkJet Printer
Sony surround sound 27kvbr10- Screen purple rainbow colors in 4 corners
I couldnot understand your problem please write your problem meaningfully...
Jan 02, 2008 | Sony 0217 Playstation 2 - Horizontal 3-D...
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
Rainbow picture
The tube needs to be degausse you had maybe placed speakers beside the tv causing it to magnetize have a tech look at it to remedy the problem.good luck.
Apr 08, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
