Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
All Pro heater will not light
Have a all pro heater that ran out fuel now it well not light. how do i check the ignitor to see if getting power.
  • 232 Answers
Since it was running good before it ran out of fuel, my guess is there was some trash in the tank that got sucked up & either/or clogged the fuel filter or restricted the nozzle. clean or replace both.
Troubleshooting tips
Posted on Dec 03, 2008
I hava an All Pro 65,000 BTU heater. It was working fine a week ago. The igniter glows, fuel mists but doesn't light off then shuts down. Ideas?
I am sure you have confirmed that the fuel is fresh and good, no water in it, etc.--
It is kerosene, not #2 Diesel fuel, right?
And the shutting down is good, if the flame does NOT ignite--- :-)
So we have to figure out why the fuel is not getting hot enough to ignite?
Question-- is the oil spray passing close enough to the ignitor?
And this unit does NOT use SPARK to ignite?, correct? --
for most of these heaters have spark ignition.. I am learning all the time, too!
How about checking the fuel pressure. and the air -- is it correct?
Check with your manual how to check and adjust.
After testing these tings, let us know what you learned
Mack B
Jan 15, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I have a All-Pro 115,000 btu multi fuel heater. When first plugged in fan runs, fuel sprays out the nozzle but heater won't fire. Any suggestions?
You probably have already checked this but is the ignitor trying to fire or not working at all ? Just curious. Thank you
Dec 17, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
All pro heater turns on but won't light and shuts off after about 15 seconds
It's supposed to shut off if it doesn't light off. Take the top off, and while staying away from the fan turn unit on and observe if there is fuel coming from the nozzle and spark at the ignitor. No fuel could be a plugged filter in the pick up tube. Unscrew the nut on the line coming from the fuel tank, the filter is in the top of the line. There is also a filter on the back of the nozzle accessed by removing nozzle and unscrewing it from the fuel tube. if there is a good fuel spray, but no spark, probably the high voltage transformer is bad. Most heater brands use the same transformer so take the old one with you to a heater dealer and have it checked/replaced.
Feb 03, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Pk115t garage heater won't start
check all of the air filters and lines to start but it sounds like the CAD flame sensor.
Feb 02, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
All-Pro 200 will not ignite.
It sound like you have either an ignition or 'dirty fuel' issue. The now Desa 'All Pro 200 T' that I have I fixed numerous times.. the approx $70 'ignitor'. But when the error code says flame' If you can tell that the thing started a flame... for a few seconds or at all.. then you can be sure that the ignitor is not the problem. .. yet. And that the flame is not a consistent lighted color.. which can meen diferent fuels mixed together..or water in the fuel. I'd try starting your heater with a high octane 'power boost' type fuel additive straight.. and then if it runs on that w/o a problem.. then you know its the fuel or fuel system.. Also you might check that the blue wire eye.. that 'looks at the flame' window is clean and wiped off with a clean cotton swab.
Nov 15, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
206 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
