Question about Spark Plugs BR4HS Plug 10/BX #3322
Motor turns over but wont start
There is no spark from wire to the plug.2003 road king
  • 169 Answers
You put NGK spark plugs in a Harley?
Get a spark tester and go from the wire to the engine block, if you get the light on the tester to blink you've got bad plugs, otherwise look for bad/broken plug wires, then a bad wire in the ignition switch, then a bad ignition module.
Posted on Dec 03, 2008
05 road king was stolen upon return frnt wiring screwed. Fixed now but it turns over but no sprk.
Hi, Tom and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, needs to be 12.5 volts or better and be able to pass a proper "LOAD" test, your battery may show 12.5 volts but has little or zero amps and must be replaced.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables shorting or leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at Good luck and have a wonderful day.
Frustrated 2003 Road King won start no spark no fuel please help
Instant Tech Relief To speak with me personally absolutely "FREE"
Apr 11, 2017 | 2005 Harley Davidson FLHRI Road King
2005 road king mis fire
The bike may misfire at different speeds or under different conditions so one would need to know these circumstances to diagnose further than spark plugs which are cheap and a good starting place.
Apr 20, 2014 | 2003 Harley Davidson FLHRCI Road King...
2003 harley davidson road king cranks but will not start
Hi Anonymous, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Nov 13, 2013 | 2003 Harley Davidson FLHRCI Road King...
My 2003 road King Wont start
Battery is prob weak.. Try jumping it with car, or battery charger
Apr 13, 2013 | 2003 Harley Davidson FLHR Road king
My 03 Road King hesitates at low speeds and runs fine at high speeds, plugs and wires are fine,and new air filter what could it be ?
Have had a similar problem,turned out to be a blocked filter on the fuel tap .From memory the little bowl undid like a light globe ES push it in and turn 90 degrees
Feb 24, 2013 | 2003 Harley Davidson FLHRCI Road King...
Harley Road King motor turned off
after checking the kill switch on the handle bars and the key. It could be a simple wire or even a computter problem check to see if you have spark if it even turns over, without knowing if it fuel injected or carb its hard to give an exact find or fix. If your not formiluar with the road kings working I would suggest you take it to a harley mech.
Sep 12, 2009 | 2002 Harley Davidson FLHRCI Road King...
How to install spark plug wires on my 2003 Road King
Okay this requires some small or really flexible fingers. the very first thing to stress is do one plug at a time!
If you look at the very front of your gas tank down at the bottom you will see the bolt on each side. The tank has a tab with rubber grommets of sorts over it. Just beneath those you will see the mounting bracket for your coil.
Now lets start with the rear jug, unplug the spark plug wire, using your fingers trace it thru the loom behind the horn, thread it thru the loom and get it clear, then unplug it from the coil. Now take your new wire thread it back fropm the jug to the coil, plug it on the spark plug, then on the coil. Repeat for the front jug. Hope this helps.
Sep 07, 2009 | 2003 Harley Davidson FLHRCI Road King...
Wiring diagram for tourpak on 2003 Harley Road King Ultra Classic
hey first off harley has a harness that will plug in the accessory outlet under the seat, now to the speakers you didnt say if you had a stero or what, now you would run speaker wire from the source to the speakers you can get the male portion (i believe)of the plug at the hd shop or just go to radio shack and get plugs(male-female) there and just soilder them shrink tube the connection hope this helps
Nov 30, 2008 | 2003 Harley Davidson FLHRCI Road King...
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
147 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
Zachary Reed
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
