Question about Kitchen Ranges
Neff elect oven b4542no i need to connect 240 volt supply to the oven. There is no indication which is active or neutral on the rear connection of the oven. The colours of the wires are yellow/green -earth black-? blue-? Please can someone give me the answer Regards RICK.
    Habit-Forming:
  • 171 Answers
The middle wire is the neutral. the green wire.
Posted on Dec 06, 2008
Does it have 2 plugs 110 and a 220
This is the oven spec, so it has to be 220 volts to support that wattage. The oven and broiler are electric and the hob is gas. Best of both worlds. (I am a chef)
Oven-Bake Element 2500 Watts
  • Oven-Broil Element 6 Pass 3400 Watts
    and then I found this :>)
    Power Power Supply Connection Location: Left Bottom Rear Gas Supply Connection Location: Right Bottom Rear LP Gas Conversion Kit: Included Voltage Rating: 240V / 208V / 60 Hz Connected Load kW Rating at 240/208 Volts: 3.7 / 2.8 Amps at 240 / 208 Volts: 15.4 /13.5 Minimum Circuit Required: 30 Amps
  • Frigidaire FGDS3065PF 30 Slide In Dual Fuel Range with 4 Gas Burners...
    Jan 31, 2016 | Frigidaire Gallery 30" Self-cleaning...
    I have a wall oven with terminals L, N and PE . Assume wires are connected in order red, black and green/yellow
    Line, Neutral,Ground 120 volt system Neutral wire should be white in color black and red wire would indicate 28/240 volts
    Feb 16, 2015 | Ovens
    Www eemaxinc com support
    My limited research indicates this heater is designed for USA electrical systems. That would mean single phase, 240/208 volts, 60 Hz. The drawings I reviewed shows a 2 pole, 240 volt breaker feeding each heating circuit. That means no "neutral wire" goes to the heater and therefore no 120 volts is needed. This is good. Kenya's system is single phase, 240 volts, 50 Hz. The heater should work reasonably well on the African system. Connect the power just like you would in the US.
    Jan 17, 2014 | Water Heaters
    Thermador c272ub double oven is it single fase wireing
    yes,the black and red era the 2 wires that supply 120 volts each for the required 240 volts necessary to operate the oven,the white is the neutral wire and the green is the case ground wire,and it should be connected to any metallic part on the oven not with the white wire,only if the power supplying this oven comes directly from the main power panel in the house and isn't off a sub panel before the oven can this be considered ok to be connected together
    Feb 07, 2013 | Thermador Ovens
    120v on bake element red wire and element wont heat up
    the reason its not heating is because you will always have 120 volts on this red wire due to its being connected directly to one side of the in coming power source,its either that you lost the other 120 volts of power coming into the unit,a tripped breaker/fuse/etc. or the control board relay that supplies the other 120 volts to the element for a combined 240 volts needed to heat the element,if you have 240 volts to the connection to the unit then you either a bad control board or the Neutral incoming power wire could be burned off which you need to get 120 volts to operate the control board which operate the relay to supply the element with the required 240 volts to operate
    Oct 27, 2012 | Jenn-Air JMW8530C Electric Double Oven
    How do I know if my Hotpoint oven 920 years old0 is on a 220 0r 120 line? The serial plate says 120/220.
    An oven uses both 120 & 220 -- actually it would be 120 volts and 240 volts or nominally, 110 volt and 220 volt.
    The 120 is used for the lights. The 240 is used for the heating elements.
    A 240 volt breaker (nominally 220 volt) -- supplies both 120 and 240 volts depending on how the supply is connected to the appliance.
    There will be a 240 volt (nominally 220 volt) breaker in the main panel for the oven. This is two 120 volt breakers side-by-side with their toggle switches connected together with a strap across the top of the toggles.
    Charlie
    Jan 11, 2011 | Hotpoint Ovens
    Jenn air oven will not heat you push bake and it says 100 but never heats up
    One side of your 240 volt connection is disconnected, most likely in the plug wire connection. The neutral and one leg of your 240 is working thereby your display still works since it runs of 120 volts. Happened to me I had one wire come loose from stress on the plug
    Sep 19, 2010 | Jenn-Air JJW8530C Expressions Collection...
    T103 clock not working
    Please read all of this post. You may burn up the 120 volt T103 timer motor is you are not careful.
    The statement: "I have 120v board with 120 constant and 240 timed" is not very clear to me as to what you mean.
    In US residential wiring, the white wire is not always the "neutral;" The white wire is sometimes used for 240 volt circuits.
    We cannot tell you how to wire your timer unless we know _exactly_ what you have.
    If your incoming supply cable (from the breaker box) has 3 wires (black, white, and bare), there are two scenarios:
    1...If the voltage from black (hot) to white (ALSO hot in this case) is 240 volts, and you have only 3 wires (black, white, and bare), then the T103 is the _wrong_ timer if you are trying to control a 240 volt load. You should use a T104 timer.
    The T104 uses a 240 volt timer motor and the T103 uses a 120 volt timer motor.
    2...If the voltage between black and white is 120 volts, then you will only be able to control 120 volt loads; then the incoming black supply wire is connected to terminal 3 and the white (neutral) wire is connected to the "A" terminal. The bare equipment grounding wire is then connected to the "GR" terminal.
    To show the difference, if you are trying to control a 240 volt load, to use a T103 and wire it _correctly_, you would need to have a incoming supply cable with a total of 4 wires (black, red, white (neutral), and bare) Black to red would be 240 volts. Black to white would be 120 volts. Red to white would be 120 volts.
    The connections would be as follows:
    White (neutral in this case) to the "A" terminal
    Black to terminal 1
    Red to terminal 3
    The 240 volt load would then connect to terminals 2 and 4
    Both the bare equipment grounding wires are connected to the "GR" terminal.
    Since you did not mention a red wire, I can only ASSUME that this is not the case.
    Sorry, we can't tell you how to wire this timer based upon assumptions.
    So, what do you have?
    Dec 23, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
    Replacing old with new
    Are the heaters rated at the same voltage, if so just connect the white to one heater wires and the black to the other heater wire..Does the white wire have a tape around it. If it does that indicates that it is a 120 volt cuircuit and not a neutral, which means you have a 240 volt supply. Make sure your heater is 240 vac.
    Sep 18, 2008 | Fahrenheat Electric Convector Baseboard...
    Electrical supply
    HI Zuso,
    Use your original wire and hook up Left to right Line Neutral, and Ground. L N G. Black wire is Line. Green wire is Ground. not sure what UK uses for Neutral. I just know that you need a big wire. And the voltage is supposed to be 220-240Volts.
    Nov 23, 2007 | Ovens
    Kitchen Ranges Logo
    107 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
