Question about Dryers
I just replaced a belt and idler pully on my Maytag SDG3606AWW dryer and now it wont start. The drum light doens't work and I've checked all the wiring I canget to without pulling the dryer completely apart again.
  • govtmod Dec 03, 2008
    Found the problem. I knocked a wire off a gizmo on top of the heater. It was accessable from the front but I couldn't see it until I pulled the drum out.
    I put everything back together and it started right up.
    Thanks!
    President:
  • Dryers Master
  • 2,651 Answers
I would check the wiring to the door,light switch, 3 wires, if i remember its GREY/WHITE/Brown. also if that was wired incoirrectly you may have blown a fuse check you outlet for power
Posted on Dec 03, 2008
Blower motor belt
It could be belt or belt idler problem or rollers or drum has twist on it or motor pully issues .
Every part of dryer drum and motor pulley and idler and belt should be examine and run dryer without top and check it with load and without load and try to isolate problem
Dec 06, 2013 | Maytag Bravos Series MEDB850WQ Electric...
I'm trying to fix my dryer. The belt broke and broke the idler pully with it. I've got both replacments, but am having trouble keeping the belt from running out of the groove on the drum and...
This link here http://www.repairclinic.com/Dryer-Belt-Diagrams shows the proper configuration of how the belt fits onto the motor/idler pulleys perhaps this will help you to keep the belt on by checking thats its properly on the motor&idler pulleys. Just find your brand and veiw the diagram.
GENE
Sep 04, 2011 | Dryers
How to put belt back on drum on my dryer
You have to take the back off of the dryer and see the motor pully and the idler pully. slip the belt around the drum, around the mototr pully and usind a flat blade putty knife, work the belt over the idler pully so that it puts tension on the belt. you may have to loosen the idler pully housing bolts, but try it first with working it over the idler as that was set for optimum tension.
Feb 04, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
How does the belt look on a maytag neptune need diagram
the belt should be on the center of the drum,
collect the loop on the botom
and feed the loop under and through the idler pully
take the loop and lift the idler pully, put the loop on the motor and release the idler
you should ba all set
Oct 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag MDE308DAYW needs a new belt. Belt was
If you go from the top. The belt goes down the drum, between the drum and idler pulloy,under the idler then pull it over to the top of the motor pully and loop over it. When it comes out from under the motor pully it goes under the drum and over to the other side of the drum, and back up to the top of the drum. I hope this makes since.
Please rate solution if helpful
Aug 28, 2009 | Maytag MDE308DAYW Electric Dryer
How to replace the belt for a whirlpool ler5620kq1 dryer
It is a very tricky task to put this belt on but I think I can work you through it. When you get the belt around the drum and get to the idler, push the belt under the idler wheel and through the forks of the idler pully assy. attaching it to the pully on the motor. Tension should be on the idler pushing the wheel up toward the drum. Hope this helps.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
Replaced idle pulley but drum wont spin when clothes are in it
Ok, when you removed the front cover to gain access to the idler pully, did you make sure that the drum didnt slip off one of the two roller wheels in the bottom rear of the dryer. If you get one of those roller wheels jammed and not in the track right, they will jam up. Look down at the bottom, grab the rollers, and pull them forward to be sure they are in the groove of the drum. Also, are you sure you relooped the belt correctly back around the idler pully? The best way to loop the belt is to place the idler pully in the correct position, then drop the belt down in front of it, loop the belt under the idler pully, push it back to tension everything, then take the loop and go over the motor pully (should be pretty tight). See if one of those solutions will help. Also be sure that you are properly getting the drum in the right position over the front seal (front should go on pretty easily, if not, reach your hand in the door, and lift up on the drum to center). Thanks and good luck!!!!
Jan 25, 2008 | Dryers
Dryers Logo
125 people viewed this question
Top Dryers Experts
