Question about Canon PIXMA iP5000 InkJet Photo Printer
Printer Ignoring Black Text
I am trying to print a document. The printer looks and sounds normal but when the document comes out only the logo at the top left (green & red cherries) and the company information (grey) print out. No other text prints on the page, even though the printer goes through the motions as if it is doing so. Normally the logo at the top left has a black outline but the printer is also ignoring this. In the text of my document I had my e-mail address and without noticing it was hyperlinked on Word I tried printing again. Same thing except that because my e-mail address was blue from the auto-hyperlink, it also printed. I have run all of the maintenance tests and when I do it says everything is fine and even prints black on the tests! I've checked all of the ink tanks which are full. I reset the printer controls to default. I played a bit with the Font options in Word and all of the color options are normal. Does anyone recognize this problem or know what could be causing this? Any feedback or help would be so much appreciated! Thank you.
  • chuck511 Mar 04, 2008
    Same problem here. The printer has 2 black cartridges, one smaller than the other. I believe the smaller cartridge 6BK is working and the other 3eBK is not. Ran all the tests, did both cleaning options, everything prints fine except the grid on the test sheet for the 3eBK cartridge. That entire row is blank on the test page printout. When I change the font color to anything other than black, the text prints fine.
  • 247 Answers
Assuming the print tests you've done so far are built into the printer: Could be worth printing a test page from the printer properties box (which you can get in XP from the START menu, Settings, Printers & Faxes, then Right click on the printer you want and select Properties from the dropdown. If the test page is OK, I'd try printing from a few different applications to see if that narrows the problem down. If the test page has the same problem, then you might try reinstalling the printer driver. A.
Posted on Feb 02, 2007
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
Erratic black fusing
I'm not real sure about how the software separates the colors, but I believe there's a way to choose a color as all colors combined to make black, or simple black.
I'm not sure if I'm making any sense, but if the printer is using all the colors to layer up and make black, then it would be a pretty thick coating and that might cause it to flake off.
Oct 30, 2007 | Xerox Phaser 7700 Laser Printer
Hp printer 7450 won't print colored text from a word document. test page shows colors on the windows logo flag. changed the ink cartridge....color one that is....no help i will try to print something else...
It may be set for grayscale (black and white) in the print properties. Go into the print properties in Word and look for a color or black and white setting, either under Color Management or Advanced. Set it for color, and then print your color document.
Jun 19, 2010 | HP Photosmart 7450 InkJet Printer
My printer does not print the test page the text. It only print the microsoft logo.
Most of the "text" on the "test-page" requires that the BLACK ink on the printer is working correctly. Refill or replace the BLACK ink-cartridge.
May 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
My HP 1280 printer does print black and white text
Could it just be that the black cartridge has run out? If not, try and clean the print heads. You should be able to do this in the printer options in Windows. It is more than likle that the black nozzle is blocked.
Dec 13, 2009 | HP DeskJet 1280 InkJet Printer
My watermarks are printing as pink instead of gray, this started happening after I changed the black cartridge. I have not made changes to the original document, and normal text still prints as black
if that is a refilled cartridge, you might have a problem with the ink. try print something (text) in pure black , and grey only, and see waht happens, if does notprint, means the printer has hard time with that black cartridge.
Jun 17, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Hi! my problem is: normal text-documents come out with white text and black background! Should be the other way round! what can I do?
with the document open, go to print, then printer set-up and text color, set to black, background color set to none. Should help
Mar 21, 2009 | Brother HL 1050 Laser Printer
HP 2015 laserjet will print text but not graphics
reinstall the printer driver from hp website
Jan 14, 2009 | HP LaserJet P2015dn Printer
Only headlines of document prints and no black text
First try to nozzle check your printer. For most cases this works best.
Dec 23, 2008 | Canon PIXMA iP90v Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Canon PIXMA iP5000 InkJet Photo Printer Logo
185 people viewed this question
Clive
Clive
old marine
old marine
