Just purchased a decktop computer and the monitor will not power up at all. i have checked connection on back of computer and it is tight and also checked the connection into the flat screen monitor and it is tight but light on top of monitor will not light up computer is powered up...
    Problem Solver:
  • 7 Answers
Check power cable,still not working replace monitor
Posted on Dec 03, 2008
S24a300b problem, not detected by pc. message on display say "check signal cable".
Check signal cable means that your monitor wire is not connected properly.
So remove your cable connect it tightly once again.
Tightly connect with cpu and power supply.
Thanks for using fixya
Aug 19, 2011 | Samsung S24A300B Monitor
Daewoo Moniter blank screen
First make sure that all the cords are connected properly from the back of the CPU to your Monitor.I suggest you to unplug all the cords of the CPU and then plug them back in after 10min. and make sure they are all connected tightly.Next check if the power cord connected to the Monitor is attached tightly.
If you still face the problem then you will have to replace it with a new power cord whih connects the CPU to your Monitor.It is black in colour.
Sep 30, 2008 | Gateway FPD2275W LCD Monitor
The monitor suddenly went black and the message - cable disconnected flashed on the screen. I checked all the cables and everything was connected and tight. I tried it on another computer to rule out it...
First, how old is the monitor? If it is still under warranty, usually under one year, then take it back to where you purchased it (with your receipt) and tell them to give you a new one. I had to do that once.
Second, The model/make/serial numbers can be found near the power chord on the back. If not there, it has to be on the back somewhere.
Jun 02, 2011 | Sony Computers & Internet
My computer is running but the monitor is black and the blue power button is dim
Ensure that the monitor's power plug is properly placed in the back of the monitor. Also be sure that the connection from the monitor to your computer is tight.
Jan 22, 2010 | Gateway FPD1975W 19" LCD Monitor
ViewSonic VX2235wm monitor looses power ...
I've not seen this problem on a ViewSonic but have on a Dell flat screen. The fix was the obvious one: the power connection on the back of the monitor was loose -- have you checked this. Also if the power cord is too tight it could be the problem. Other then this, it sounds like a short inside the monitor.
Hope this helps
Mar 17, 2009 | ViewSonic VX2235wm LCD Monitor
Monitor does not stay on
i think this is the problem of your monitor eht get it repaired
Nov 22, 2008 | ZT Group CISNET A7050 PC Desktop
Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Apr 29, 2008 | Acer AL1916B 19" LCD Monitor
Viewsonic va721 monitor
Connect the monitor to a different computer system (if available) to see if the issue is with the video card or the monitor.
Make sure A/C power cord is securely connected to the LCD display.
Make sure the video cable supplied with the LCD display is tightly secured to the video
output port on the back of the computer. If the other end of the video cable is not attached
permanently to the LCD display, tightly secure it to the LCD display.
Your backlight may be going bad, or the small controller board may be going bad also.
Nov 29, 2007 | ViewSonic VA721 17" LCD Monitor
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
