Question about GE JBP71 Electric Kitchen Range
I had all my burners on my GE range on close to high heating level and the oven on and then they all started to cool down. Nothing will heat up. The panel works and I've removed the burners and pluged them back in but nothing will heat up. GE Model J BP35W0K1WW
    Scholar:
  • 162 Answers
Stove have an eletric problem geting the 220 volts to heat up it's only working on 110 volts.
Posted on Dec 06, 2008
GE Model J S968S0F4SS. During bake display goes bake, oven turns off.
Oven Does Not Heat, But The Burners Heat - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
Range - Oven Does Not Heat, But The Burners Heat. To minimize the ... Turn yourrange OFF and either remove the fuses or turn the breaker OFF. Then unplug ...
How To Fix Oven With Little or No Heat When Baking ...
Troubleshooting Why Your Oven Won't Heat ' PartSelect ...
? 2:54
https://www.youtube.com/watch?v=ketJHf3rrSk
Sep 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your oven may not be heatingproperly. ... Neither the bake or broil elements ..
Oct 31, 2015 | GE Kitchen Ranges
When i turn on the oven it starts up as normal , "on" then "Preheat" then runs. About 30 minutes later both the "oven on" and the "preheat" indicator lights start blinking.
follow this test and fix it. God bless you
Oven Igniter
As the oven igniter weakens over time, it will take longer for the gas valve to open. If the oven doesn't bake evenly, it may be that the oven igniter isn't opening the gas valve when it should. This will cause the oven to cool down more than it should before the burner reignites. The oven temperature should not cool by more than 40 degrees before the oven igniter relights the burner.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't heat the problem is usually with the heating components. However, if the oven control board is bad, it might not send voltage to the heating components. To determine why the oven won't heat, first test the simpler components in the circuit. The oven control board can't be tested easily and will have to be replaced if it is defective.
Nov 04, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
The burners either don't come on or they have to be turned on HI to come on. When I turn the heat down, sometimes it turns down sometimes it doesn't. Other times I have to push on the burner to make...
Let me get this straight. You want me to pay you to fix this problem.
But, if I already found a solution you want me to tell you what solved it !
You must have a really over sized uterus !!!!!!!!!!!!!!!!!!!!!
Oct 17, 2009 | GE Kitchen Ranges
Ge jvm1540dm2ww over the range unit: have a gas range and the fan on the above mounted microwave once in awhile turns on automatically while something is cooking on the range below it....
The heat sensor in the electronics panel senses the rise in heat from the stove below. Once the amount of heat reaches a certain level, the cooling fan turns on to keep the electronics inside the microwave cooled.
I wouldn't worry about it. mine does the same thing.
Jun 19, 2009 | Microwave Ovens
I have an older GE self-cleaning oven. It has an
Latch may have been damaged from heat of self clean. lift top where burners are, should see cover over latch assy(turn power off to unit) remove screws for cover and should be able to free latch.
Jun 08, 2009 | GE 30" Self-Cleaning Freestanding Electric...
Oven Wont Preheat
does the bottom element get hot? could be a bad heating element.
Feb 01, 2009 | GE Kitchen Ranges
Burners, oven will not heat, all lights work
Sounds like you are only getting 120 volts. All heating elements require 240 volts to operate. Start by taking the covers off the back of the range and looking for loose or burnt off wires. Look first at were the range cord connects onto the range. If all OK with range wires, check wires inside range receptacle (where the range cord plugs in) and also the connections on the household circuit breaker or fuses. If you use a meter to test for 240, you may see it, but if a connection is poor, it may not be good enough to supply the required power.
Oct 02, 2008 | GE Spectra JBP78 Electric Kitchen Range
GE Profile Still Heating with nothing selected
IS THIS A DIGITAL RANGE,IF SO REMOVE THE TOP BACK COVER AND SEE IF ANYTHING ARCED(BURNED SPOTS) ON THE CONTROL BOARD,IF NOT DIGITAL, YOUR OVEN KNOB SWITCH IS STUCK IN CLEAN MODE,I HOPE IT'S NOT THE CONTROL BOARD AS THEY RUN ABOUT $200 ,LET ME KNOW-MIKE
Jun 15, 2008 | GE JBP65 Electric Kitchen Range
No heat at burners or oven
check your fuse / breaker box make sure you have power (sounds like you dropped a leg of power) make sure breakers/fuse is on/good flip it to off the to on if oven don't work then take a look at the cord to the range check power at the wall then open where cord goes into range check power or you may even find the cord burnt in there if so replace all damaged wires good luck
Dec 21, 2007 | GE JBP82 Electric Kitchen Range
GE XL44 Oven - On/Off heating of bottom burner.
Mag...not sure here. Is there a particular reason that you're suspecting a problem? Does the unit heat much slower than before? Does it bake properly? You may be looking for problems that aren't.
Dec 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
GE JBP71 Electric Kitchen Range Logo
133 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
