Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Need to take panel off to clean coils
Don't know how to take the front bottom panel off to clean, refrigerator Kenmore coldspot is running a lot more often & I know it needs vacuuming.
  • 1 more comment
  • mckcraft Dec 03, 2008
    Clarification Yes the coils underneath--that louvered panel at the very bottom should come off. I don't want to break it and can't fine the manual.
  • mckcraft Dec 05, 2008
    It worked thanks--had to wait til daylight to see it.
  • Ken Bledsoe May 11, 2010
    Are you talking about the coils under the refrigerator?
  • 306 Answers
Okay it is just held on by two small squeeze type clamps. Take a little flashlight and locate the clamps. Either lift and remove or pry off very gently only way to see is looking at it from ground level. ken
Posted on Dec 03, 2008
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
Apr 14, 2013 | Kenmore Refrigerators
Do i need to clean coils?
you dont new unit are sealed, some have a filter in front at the bottom vent.
Sep 23, 2012 | Maytag MSD2651 HE Side by Side...
Kenmore Coldspot model 106-56239400 -- how do you remove the water collector at the bottom?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
If you need more help GO HERE:
Thanks for using fixya
Leo Ponder
Sep 20, 2011 | Refrigerators
Kenmore Coldspot 106-52609100 side by side is not working, freezer is only cold at the bottom and the refrigerator is not as cold as it should be. I opened the freezer to get something out and noticed the...
Can not type all the answers to you cause it is very log for me to do that.
You can use this link to solve what ever problem you would want to check consigning you fridge. It will surely help you out.
You can check very well and the solution will be solved.
Take care.
Apr 20, 2010 | Refrigerators
My freezer on my Kenmore Elite Coldspot refrigerator model 10672206201 (freezer on top) is not cold enough. I don't know where the compressor coils are to check them. What else besides checking the...
The coils are on the bottom of your fridg next to the compressor you can see them from the back.
or if yo take the plastic panel in the front of the weels you can see it also.
the only other element i think of is the thermostat unit that in your fridg, but if your unit cold then it is not the thermostat.
Jan 02, 2010 | Kenmore Refrigerators
I have a Kenmore Coldspot Top Freezer refrigerator. Everything in the freezer is really, really cold, but the refrigerator is not. I tried to clean the coils at the bottom, but I could only get to the one...
There is an ice blockage between the freezer and the refrigerator. Cold air passes from the freezer into the refrigerator in the back behind the plastic housing with the temperature controls. Empty your freezer and remove the bottom panel. You will see that everything is frozen. Carefully remove this ice until you can clear the passage to the refrigerator. It may be helpful to remove the temperature control housing in the refrigerator as well to see when the ice is cleared.
Oct 03, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge side not cooling
the coils are at the bottom but that dose not sound like the problem u need to check the de frost
Nov 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite Bottom Freezer Refrigerator Model 795.7554
the condenser coil on this is located in the back side and removal of the rear cover is need to get to the coil. It's on the right side looking at the back. make sure to unplug the ref before taking the back off.
Aug 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirpool refrigerator runs too long
First thing is to check the condenser coil( outside coil) and see if dirt has accumulated on it. if so clean it off. The condenser coil should be located under the fridge, or behind the fridge.If you do clean it, and its still running a lot, then its possible that the unit is low on refrigerant. If that's the case you will have to call a service tech to look at it
Jan 28, 2008 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
112 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
