Question about Kenwood KDC-135 CD Player
Kenwood kdc516s, cd audio does not work, it can be inserted and removed, it shows track information and elapsed time but there is no sound, is there a fix?
If your car has a factory amplifier, you probably tied the kenwood's antenna turn on lead (blue) with the factory amp turn on wire. That bue wire only supplies voltage when your source is tuner. you need to use the kenwood' amp turn on (blue/white) to get the factory amp to turn on with the cd player and the tuner
Posted on Feb 09, 2009
Onboard LCD display
did you try to insert a different cd? see the settings like OSD button on the remote control or display to view the tracks.
CHARCOIS
Sep 13, 2008 | Toshiba SD-4900 DVD Player
Mine goes crazy too
trying doing this when it says code off
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Jun 29, 2009 | Kenwood eXcelon KDC-X769 CD Player
KDC-716S sometimes plays CD, other times just tray drop
Type 1
Type 2
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Jun 01, 2009 | Kenwood KDC-716S CD Player
Kenwood KDC-X589 seems like the CD player doesn't put out sound
you have to change the cd read setting it might got set to cd read 2 it needs to be cd read 1 in standby mode press menu button scroll through with track button till you see cd read and set it to cd read 1 if not in standby mode try in cd mode same steps
Jul 03, 2008 | Kenwood KDC-X589 CD Player
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
No sound on cd, (kenwood kdc-x469)
did you try another cd maybe your player needs a little cleaning and is your cd new or older
reason i ask is cause newer cd's have a different format then older cd's from a year ago its getting hard to play new stuff on old stuff
May 06, 2008 | Kenwood eXcelon KDC-X469 CD Player
Ok I had the kenwood KDC-MP235 installed and...
The front aux input is only capable of accepting audio signals and definitely won't display any track tags.
If you have an iPod, I think with the KCA-iP500 adapter it will display song info on the front as well as allow control from the Kenwood's controls.
As far as the song info on a CD - it should display if you've got a CD with CDTEXT info on it, or if you're playing an MP3/WMA CD. Most regular audio CDs won't be able to display song info.
Feb 21, 2008 | Kenwood KDC-MP235 CD Player
Settig time on clock
HI Joe,
Try to see if this procedure will work for you.
Nov 12, 2007 | Kenwood KDC-516S CD Player
Kenwood KDC-135 CD Player Logo
118 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
