Question about GoVideo VR3845 DVD Recorder/VCR
Stuck in safe mode
I have a VR 3845 That is stuck in safe mode and the doors
will not open. Its only a couple of mo. old. I also need the code
for the remote.
Thanks, Kenneth.
waltonkenneth@msn.com
There is a botton on the remote (Lock) that puts in safe mode and off.
Posted on Dec 04, 2008
How to get out of safe mode step by step
PC stuck and cannot exit Safe Mode in Windows 10 8 7
Alternatively:
Steps that you need to go through in order to fix a Windows 10 computer that is stuck in Safe Mode:
Press the Windows Logo key and the R button at the same time to open a Run
In the Run dialog, type msconfig.
Click on OK or press the Enter
In the event that you are prompted by UAC, click on Yes.
In the System Configuration dialog that appears, click on the Boot
Clear the checkbox beside Safe boot by clicking on it. This will change the computer's default boot mode to normal.
Jun 10, 2017 | Computers & Internet
Stuck in safe mode on my old gateway
Everything is messed up Trying to correct will only drive you insane
Do a clean install
Apr 01, 2014 | Computers & Internet
I upgraded my argosy hv335t firmware to 2.3 then rolled back to 2.1c (all upgrades done from a usb device which was safely removed from pc) after the player did the upgrade it restarted then got stuck on...
go to this site: http://www.argosyusa.com/download.asp?DefaultTab=0
there are two different verrsion of the HV335T one with "VR" after the barcode and the other with no "VR" after the barcode you will see what version is the one you need
for no "VR" code are this firmwares D2.35 (beta) V2.3 V2.1c V2.0 V1.01 (original in the player)
for "VR" code are this firmwares B1.35 Same as D2.35 for HV335T VR R1.1 Same as V2.1c for HV335T VR so, download the one you player needs and do the upgrade
Leo
Feb 12, 2011 | Argosy HV335T
Etc fail safe mode codes p2104 2107 2110 2111 2112
P2104 Throttle Actuator Control System - Forced Idle
P2107 Throttle Actuator Control Module Processor
P2110 Throttle Actuator Control System - Forced Limited RPM
P2111 Throttle Actuator Control System - Stuck Open
P2112 Throttle Actuator Control System - Stuck Closed
Seems like Throttle Actuator is the problem.
Good luck on this repair.
Jul 13, 2010 | 2005 Lincoln LS
GO Video VR 3845 DVD/VCR combo will not turn on.
Yes,if u want to.Unplug,replug the unit back after about an hour or so.The unit should reset it self out of protection mode and work again,if nothing in the circuit boards are burn.
Jun 15, 2010 | GoVideo Go Video DVD/VCR Combo
Hatch back will not open
With key in hand,hit power door lock switch to lock. Raise release handle & lower. Hit power door lock unlock raise & lower handle. May take a couple times is stuck in limbo between lock & unlock mode.
Jun 07, 2010 | 2001 Volvo V70
Rear n/s door of Touran will not open from inside or outside, remains locked. All other doors open OK
its probably the door lock wich could be faulty and is stuck in safe mode.may need to take it to a dealership to have it fixed.
Oct 16, 2009 | 2005 Volkswagen Passat
Go video DVD/VCR recorder Model number VR-3845
First make sure you are using a quality disc like:
memorex Brand dvd-r.
Dec 25, 2007 | GoVideo Go Video VR3840 DVD Recorder/VCR
HP Deskjet 3845 print queue not clearing
Have you tried going to safe mode, turning off the printer and manually opening it at the control panel>printers... try and delete or cancel prinitng at these settings...
Dec 09, 2007 | HP Deskjet 3845 InkJet Printer
Sony DSC T33
Try to move the mode button fast and stop it right in the middle with a snap. Do it a couple of times to change between video and camera mode. It should help ~vr
Aug 15, 2007 | Sony Cyber-Shot DSC-T33 Digital Camera
GoVideo VR3845 DVD Recorder/VCR Logo
345 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
