Question about Konica Minolta PagePro 1350W Laser Printer
Does not print
The printer will not print. Tried it in both USB and parallel. Computer screen shows it printing. On print command the green light flashes as if it were printing then goes to normal but paper was not moved. Computer thinks it printed.
  • Anonymous Dec 22, 2007
    I have the 1350W hooked up to two computers. One (the XP) works fine. The other (Vista) was working but stopped when the computer crashed and I had to go to a previous setting to get it to work again. I need to get a download which will work with Vista. Thanks. Pat De Esposito
    deesposito@earthlink.net
    Novelist:
    Champion:
  • 202 Answers
Eratliff, As someone mentioned on one of my last responses "have you checked to see if the rollers roll. Using latex/rubber glove make sure the rollers are moving." What was the last thing the printer did before it wouldn't print? Was there a paper jam? or even just a small piece of paper stuck in the rollers. Have you uninstalled all the printer drivers and make sure any copies of the printer is deleted from printer properties. Go to this site: http://printer.konicaminolta.com/support/current_printers/pp1350w_sup.htm#drivers and download and install the latest and greatest drivers. Also make sure your machine is up to date. Otherwise you may need ot take it in or... Good Luck Tim
Posted on Feb 03, 2007
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
My Printer is not printing although the printer status is online. How do I fix it?
If you tell it to print and the item goes into your Que for printing. In that screen click on the printer tab... In the drop down verify that the "Use Printer OffLine" does NOT have a check mark next to it.
Dec 30, 2013 | Zebra LP 2844 Thermal Printer
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Printer doesn't work when use usb parallel converter.
Forget about using parallel converter. Just use the USB cable it works best anyway.
Easiest way is this.
1: Turn printer on. (Green light. ready to print)
2: DISCONNECT the usb cable from the PC.
3 DELETE the Zebra LP2844 & Zdesigner drivers from the printers & Faxes folder. Just highlight them and hit the delet key. Don't worry Iknow what I'm doing.
4: Plug in your USB cable back into PC.
Just sit back and wait, your PC will automatically detect your printer and re-load your driver software.
Send me the cheque now!!
May 12, 2009 | Zebra LP 2844 Thermal Printer
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
My computer cant find my printer its a lexmark 2600
Have you tried the following steps?
1. Power off your computer.
2. Power off the printer and remove the power cord.
3. Check the cable connection between the printer and the computer to make sure it isn't loose.
4. Put the power cord back in the printer and power it up. Do all lights show up as normal? Green? Or are some flashing?
5. Power on your computer.
6. Under the printers folder, right click the installed printer and go to properties. Print a test page.
How is the printer connected? USB or parallel port?
Apr 19, 2009 | Office Equipment & Supplies
New Dell Inspiron connected to HP 820Cse printer. Won't print.
I've not worked with one of these cables before, but here's what I would do: Right-click on the printer icon and go to properties. You'll be looking for the tab that says "ports." Open that tab and see what port the computer thinks it's using for the printer. Chances it says it's using a parallel port, but it is in fact, using a USB port. I can't tell you which to choose without looking at what you see, but I think you might find one that makes reference to a USB port with a parallel connection of some type. Try clicking on that and see if your situation improves.
Feb 24, 2009 | HP DeskJet 820Cse Printer
Printing does not work on Xerox Workcenter XD125F
Does the printer show up when you unplug it from the USB port and plug it back in? Does it say New Hardware or Printer found?
Does it print from a parallel port or does your computer have one?
Unlikely the cable since I have used those on that product before.
If it will print from a computer parallel to parallel, I would suspect the cable obviously.
You can take the back off the printer and reseat the board, and connectors.
What happens when you popo the printer itself?
Jan 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Epson stylus C44UX and zps1001 zonet print server
Since it's over a year since we had any response on this, I think we might call it "Solved by Poster".
Jan 13, 2008 | Zonet 1-Port USB 2.0 10/100 Mbps Print...
Konica Minolta PagePro 1350W Laser Printer Logo
99 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
