Question about Frigidaire FEF376 Electric Kitchen Range
The ESEC lockout feature is on. The slide in stove is brand new and just turned on and we can't get it out of the locked mode.
    Habit-Forming:
  • 171 Answers
You can unplug the stove and plug it back in that will take the looking position. and in other models, set the oven to clean the oven for 5 minotes, and it will go of and will relace the oven door.
Posted on Dec 06, 2008
Stove top error code E 15
Thank you for your post, friend!
From my understanding your Electrolux range is displaying an error code of "E15". An "E15" code stands for the ESEC self-test failed. This might be an issue with your ESEC (Electronic Surface Element Control) board or ESEC-UIB (User Interface Board). Before seeking any assistance with a professional technician I would advise you to perform a reset on your range. You can perform a reset by disconnecting power from your range for roughly ten minutes. If that does not help resolve your current issue I would suggest consulting with a technician for repairs. Hopefully this information is helpful. -Matt
Feb 15, 2015 | Electrolux Cooktops
My stove have code f 23 What this mean?
Thanks for your inquiry, Adrian Gonzalez!
From the information you have provided your Electrolux range is displaying an error code of "F23". "F23" stands for communication failure between the EOC (Electronic Oven Control) and ESEC (Electronic Surface Element Control) I would attempt to perform a reset on your range and you could do that by disconnecting the power from the range for ten minutes. If you continue to experience a problem with the error code it could be an issue with the EOC or VSC (Variable Speed Control) board. Hope this helps. -Matt
Nov 22, 2014 | Electrolux White Gas Slide In Stove Range...
What does E15 fault in a electrolux stove mean?
Thank you for your inquiry, friend!
I understand that you are looking for the meaning of "E15" on your Electrolux range. "E15" stands for ESEC self-test failed, which could either mean and issue within your UIB (User Interface Board) or relay board. I would recommend having a professional come out to diagnose and repair your appliance. Best of luck. -Matt
Aug 19, 2014 | Electrolux 30 Inch Black 30" Electric...
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
Electrolux oven won't heat up at all
Hello Le'Cinda Rhone - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Sep 27, 2012 | Electrolux 30 Inch White 30" Electric...
My remote control (SKY-3001) doesn't seem to communicate with the propane stove.
Sounds like either the batteries are weak or it's lost it's security code. Also, be sure the slide switch on the front of the receiver (the Black Box) is in the Remote position. If after changing ALL the batteries (4-AA in the receiver and 2-AAA in the hand held remote) and they're all positioned properly and it still doesn't work, check the LCD screen to see if the child lock or lock out has been activated. If so, deactivate by pressing the Mode button and the Up button at the same time and hold for 2 seconds. The Lockout icon should disappear.
And finally, if all else fails you'll need to reset the security code. There are 1,048,576 unique security codes, but you'll need only one.
When matching security codes, be sure the slide switch is placed in the REMOTE position; the code will not "LEARN" if the slide switch is in the ON or OFF position. Program the remote receiver to learn a new security code by using a very small scree driver to push in the LEARN button (on the top of the fron of the receiver to the left over the ON position) while at the same time pressing the MODE button on the hand held transmitter. A change in the beeping pattern, at the receiver, indicates the transmitters code has been programmed into the receiver.
The microprocessor that controls the security code matching procedures controlled by a timing function. If you are unsuccessful inmatching the securiy code on the first attempt, wait 1-2 minutes before trying again - this delay allows the microprocessor to reset its timer circuitry and try up to two or three more times
If all of the above solutions fails to solve your problem contact SkyTech Technical Service at 888-672-8929, Monday - Friday.
In the meantime, if you want or need to use your gas log stove for supplemental heating, move the slide switch to the ON position and the burner(s) will light. That's assuming that the gas control valve on the gas log stove is turned to the PILOT position. To turn it off, move the slide switch to the OFF Position and the burners will go out and the pilot will remain burning.
Good luck. Please let me know how it worked out for you.
Feb 06, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
I have a frigidaire m/n PLES389ECD and the burners and oven aren't working and had the error code f20, the clock timer was replaced but now the clock is the only thing working the burners and oven still...
The ESEC system and the electronic oven control ain't communicating. Check the wiring connections between the oven control and the esec controls. The thang is designed to lockout the top burners while the self clean feature is in use. If you failed to reconnect that connection which feeds back to the ESEC I imagine nothing does work. LOL. here's a video which shows how it works and I have the manual loaded on Gdocs fo you.
30 Inch Freestanding Electric Ranges_Rev A (5995438461).pdf (4 megs) printable.
Dec 31, 2010 | Frigidaire Ovens
Brand New Frigidaire slid in stove
look closely at the control buttons one should also have that same icon on it somewhere, youll need to hold it in for 3-5 secs to unlock the controls. its a child safety feature so the kids wont accidentally turn it on
Mar 16, 2008 | Frigidaire FEF376 Electric Kitchen Range
Range goes into lock out mode for no reason
I posted a similar problem earlier today but never saw it come up. Anyway I found the problem for me. My problem was a "LOC" display came up when I plugged the stove in after bringing it home (bought used off craigs list). This made the stove top inoperable, no gas supply.
SOLUTION:
There is a Cooktop Lockout as part of the night light switch which you hold down for 3 seconds to activate or deactivate. This is not the same as the Control Lockout which is next to the switch I am describing. Anyway doing this will make the "LOC" display go away and you will hear the gas valve activate or deactivate respectively.
Jun 14, 2007 | Whirlpool GS563LXSS - stainless Steel Gas...
Frigidaire FEF376 Electric Kitchen Range Logo
283 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
