Question about Mitsubishi WS-65809 65" Rear Projection Television
Hit wrong TV remote button, knocked out HD programming
Picture no longer clear, shadows on letters and around people on screen, picture is bowed, and some channels don't come in anymore. Also, when switching channels, looks like not programmed, lots of bars and snow until picture comes in.
  • 505 Answers
You have multiple issues. The shadows are likely convergence IC solder connections breaking or the ICs actually failing. If you can bump the tv to get it to re-align, it just needs resoldering. If it doesn't snap back, it needs new ICs. The channel issue is less common and could be a number of things. You may want need to just autoprogram again to, but may have a fluid leak issue. You can unplug the tv and remove the back panel to inspect for fluid on the signal board (board with tuners, where cable plugs in).. DON'T touch the fluid, highly toxic stuff. Take a bright light and see if any drops have made it down to the board. If so, the severity of the leak will determine the repairablity. Try using a VCR or cable box to bypass this problem if no fluid leaked, that is the best (cheapest) way around it.
Posted on Dec 06, 2008
My wife was cleaning the front of our flat screen tv ....she must of hit one of the buttons on the front of the TV ....the picture went smaller How do i get it back to normal size?
Can't changes tv picture screen sizes,when the tv is off.She is cleaning the tv,when it is off wright?Yes.Than the tv programming u are watching stay small screen size the whole entire times even different seen or in commercials?Tv even in difference tv channels,screen sizes are small too?Sometimes tv changes screen sizes by itself to fit the tv programming it is playing to fit it prgramming format it displaying.Still have all small screen sizes all the tv channels.Tv must be on and playing.U have the tv original remote wright?Yes.Try looking on ur tv remote control look for a buttons said like Aspect Ratio,Picture Sizes,ZOOM or VIEWMODE buttons,by pushing one of these buttons on the remote should able to changes tv picture screen sizes.
Apr 13, 2011 | Insignia IS-LCDTV32 32 in. Television
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
I left my 60 inch rear projection mitsubishi HD 1080 on overnight as I fell asleep in front of it for about 5 hours (11pm - 4am). This morning when I turned it on the picture is doing a fisheye effect on...
It sounds your Mitsubishi rear projection tv got problem with convergence output chips failure, I'm not aware about model number of this tv so unable to provide you specific info however, it is hardware failure and few parts need to be replaced by tv repairman.
Convergence output chips make align picture on front screen and if they stop working, you will see 3D look or bowed picture with different colors.
Contact local tv repair shop to fix this issue in tv.
Thanks.
Nov 17, 2010 | Televison & Video
Hitachi 50v500, we just put in a new lamp, now the picture on the screen is slightly doubled, what do I do?
Here is what I suggest----look at lettering and or put the mode to 4X3 which is smaller left and right.
Look at the edges of that picture or lettering on screen---this model sometimes has a ghosting where images have a slight shadow, like with rabbit ears.
If this is the case there is a way with the remote to CORRECT IT.
I have the information--confirm if slight ghosting around letters--it can be white or any color.
I have seen this before.
SD TECH
Sep 10, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
The letters have worn off HD tv insignia remote.
The owner's manual and other useful downloads can be found at InsigniaProducts.com. Just search for your TV model number!
Mar 07, 2010 | Insignia 42" LCD Flat-Panel HDTV
I'm new to the HD world...just purchased a LG 42LH40 a couple days ago...and have a couple questions to make sure my TV is operating right. 1) When watching an HD channel (CBS for instance) there is about...
Check in the manual or with the manufacturer, but the TV should auto configure the picture based on the signal.
I have a Toshiba that does the same thing.
There is no mistake when HD is in effect, as the picture is superb.
Jan 09, 2010 | LG 42LH40 LCD TV
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
High def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Dec 27, 2007 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Mitsubishi WS-65809 65" Rear Projection Television Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
