Question about Daewoo DVRS05 DVD Recorder/VCR
Daewoo DVRS05 Recorded DVD won't play in OTHER DVD players
In this unit I can record a VHS tape to a DVD+R easily enough, and the recorded disk plays in the same DVD drive the recorder is on. It will even play on any computer's DVD drive and software. However, it will not play on another DVD player, that is, a standard player hooked up to a television. I've tried all kinds of standard players, and none will work. Each player says "disc error". That's all the info I get. Any ideas?
  • raulruzm Feb 13, 2008
    In this unit I can record a VHS tape to a DVD+R easily enough, and the recorded disk plays in the same DVD drive the recorder is on. It will even play on any computer's DVD drive and software. However, it will not play on another DVD player, that is, a standard player hooked up to a television. I've tried all kinds of standard players, and none will work. Each player says "disc error". That's all the info I get. I HAVE SAME PROBLEM PLEASE SEND A RESOLUTION ON MY E-MAIL
    RAUL RUZ M raulruzm@gmail.com
    Problem Solver:
  • 12 Answers
My suggestion from reading other forums is that these players sometimes have problems finalizing the disc.. you could try making a copy of the disc in a computer to see if this fixes the promlem or maybe media these use dvd+r and has a lot of compatibility issues with dvd players.
Posted on Feb 27, 2008
I have had exactly the same problem videos copied on daewoo recorders om dvd+ dvd won't play on an other dvd players have you reveived and replies or do you know how to fix this Gerry
Posted on Oct 10, 2012
Can't view recorded DVD
if the movie you recorded ? was copy protected. then your dvd prob did not record
Nov 22, 2012 | Magnavox ZV427MG9 DVD Recorder/ VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
DVD drawer will not open, has locked DVD in
I am assuming the electronic disengage button is not responding.
Exit programme and use a paperclip gently into the small hole in face of draw and it will trigger a manual release
Dec 28, 2008 | Daewoo DVRS05 DVD Recorder/VCR
DVD recorded discs (from VHS) do not play on other dvd players
I called the manufacturer. They admitted to improper instructions. They provided me a fix to their copying protocol and it worked. Also, they game me instructions on how to fix already copied tapes. It works well and I would have to say I was impressed with their customer/technical service.
Dec 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
PD DVR100
Hi again,
This is a placeholder and would look forward to the diagrams.
Cheers.
Jul 28, 2008 | Protron PD-DVR100 DVD Recorder
Samsung DVD-V$357 recorded dvds won't play on other machines
Did you finalize the disk? If not, this should solve your problem. When the disk is finalized you should be able to play it on your computer if you can play other DVDs on it. Some other DVD players can only play specific disks (i.e. DVD-R, DVD+R). This may be another problem.
pjrsop
Mar 14, 2008 | Samsung DVD-VR357
I cannot watch my dvd's i taped on the philips on any other dvd player
YOU MUST FINALIZE THEM BEFORE YOU PLAY IN OTHER DECKS, CHECK YOUR MANUAL
ON FINALIZING THE DISK
Dec 17, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
Daewoo DVRS05 DVD Recorder/VCR Logo
471 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
