Question about HP Officejet Pro L7590 All-in-One InkJet Printer
Cutting off end of paper on legal size copy
We are trying to make a legal copy but it cuts off the end of the page - at about 8" x 12 " ????
  • prousa Dec 06, 2008
    cutting off end of paper on legal size cop-y problem need solution
  • resrealty May 14, 2009
    I have the same problem. Note: this in in the "COPY" mode from the panel, not the "print" mode.
Have you went to the print menu and minimized the border? try this it works on the HP K550.
Posted on Dec 11, 2008
Brother 9840 print on legal size paper
it seems that on your model you can only use legal size paper on tray 1 & 2, then you have to set the paper size.
here is a link to instructions for your model.
http://download.brother.com/welcome/doc002258/mfc9840_uk_usr_b.pdf
Feb 19, 2015 | Brother MFC-9840CDW Laser Printer
Lexmark Pro901 When scanning from document feed the machine seems to scan only a part of the page whilst cutting out the information at the bottom of the page.
Make sure to set the correct paper size when scanning from the ADF. If you're scanning a legal size document, set the paper size to legal.
If it doesn't work, try to reset the printer back to its factory settings:
1 From the home screen, touch Setup (wrench icon), and then touch Use Factory Defaults.
2 Touch Yes.
3 When prompted to set the initial settings of your printer, make your selections using the touch screen.
Oct 12, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Everytime i print something in a label sized setting it always cuts into short
Before printing try using print preview first and adjust yur settings from there. Or go into control panel select printers and reset to default settings, restart your computer and try again. Good luck.
Sep 09, 2012 | Canon IP2700 Inkjet Printer
I need to scan then email a legal page size document, it is cutting of part of my pages?
Hi you need to go to scanner icon and click right mouse and choose the paper size to legal size. Otherwise it will scan in normaly paper siza which is a4 size or letter size.
Feb 21, 2011 | HP Computers & Internet
My printer has legal paper in it...It is set to legal size, however when it prints it cuts it off like it is letter size
Most office productivity software, including Microsoft Word require that you set the paper size within the application to legal as well.
In Word, click on File then click on Page Setup...
On the Page Setup menu, there is a Paper Size tab. This is where you can let Word know what size paper in in the printer.
I hope this helps.
Aug 20, 2009 | Xante Accel-a-Writer Laser Printer
Can't priny 8.5x14
program is set to 8/11 print size in progrm options paper size
Apr 22, 2009 | HP PSC 1210 All-In-One InkJet Printer
When scanning cuts off the end of the page.
sometimes, if you place the original legal size in the df, and the end of the paper (as if you just took it out of an envelope) doesn't quite lay all the way down, the sensors on the df will be tricked into thinking that the original is only letter size.
if this is the case, then, there should be about 3" cut off of the scan.
Apr 01, 2009 | Canon imageRUNNER 5570 Copier
I am trying to print onto legal size paper with a lexmark C532n. Is it possible?
yes.it is possible.you will just have to select the legalsize in the printer properties to print on the legal size paper.if not selected the printout will get cut little bit from its end. ok.
Jan 06, 2009 | Lexmark C532n Color Laser Printer
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
How do i get my printer to print a legal size copy
In your printer settings as you hit print
select the printer setting prefferences
select paper size( change from letter to legal) and your problem is solved
When you copy through the software program from brother you can change this in there. Just redo the prefferences.
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
215 people viewed this question
Seeker5211
Seeker5211
