Question about Toshiba 53H71 53 in. Rear Projection Television
My picture goes out every few seconds or when a loud noise is on the television. If I smack the top of the t.v. the picture will come back...till the next loud noise. I have a theatre sound t.v. so no loud noises is impossible!! Please help. My t.v. is from 1996.
    Genius:
  • 1,550 Answers
It is due to bad solder connection in your tv . You need to take your tv to service repair to check all connection .
Also a chance of faulty capacitor on the circuit board .
Posted on Dec 03, 2008
    Genius:
  • 1,847 Answers
This seem like a loose soldered IC.
  • Legin Varghese
    Legin Varghese Dec 03, 2008
    You have to check for that ic and get it soldered back or replace the IC itself. This IC will die in a month or two anyway.
    Kevin
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Loud noise from back of tv
You most likely have a bad color wheel. You can easily determine this if the sound goes away within a few seconds after turning the set off.
Jun 29, 2010 | Samsung HL-R4667W Rear Projection...
Amplifier turns on and works till it gets hot then
This sounds like a problemn the power supply area, possibly near the filter caps. I would look for a cold soldering joint at or near the filter caps as a start.
The problem is a mechanical connection problem since vibration "fixes it".
Capacitors are heavy and often due to handling the soldering is broken at the terminals. As unit heats, these start to oxidize and break contact, but vibration temporarily restores them.
Dec 17, 2009 | Peavey Music
After a few minutes the picture goes haywire and a loud high freq
Hello
This is a warranty issue. Either take the TV back to SAM's club or call Vizio for a warranty repair.
Jul 28, 2009 | Vizio L32 32 in. LCD HDTV
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic PT-53WX54 What is that popping noise?
A loud popping noise, like a sharp "snap!", is usually caused by high voltage arcing. Somewhere in the high voltage system an insulator may be cracked or loose, such as the plastic around the flyback transformer or one of the rubber cups on a picture tube. When the high voltage arcs, it momentarily drops and the picture could go out for a split second. High voltage is dangerous in projection sets so allow a qualified tech to service it for you.
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
