Question about Whirlpool Duet GHW9150P Front Load Washer
Bathroom door will NOT close because rug is too thick
I have regular size rugs that need to pass through the bottom of the bathroom door and the door is too low to the floor. What can I do to make the bottom of the door higher?
    President:
  • Whirlpool Master
  • 2,651 Answers
Remove from the hinges, mark up the neded amount and cut with a saw. its that or youl need thinner rugs
Posted on Dec 03, 2008
WILL i HARM the hardwood floor under my Area rug to be shampooed. No pad underneath
Simple answer: YES
Anytime you are sampooing anything the under surface will be exposed to the cleaner. Move throw rugs to a location safe for the cleaner. Kitchen floors are usually good for this or a concrete floor. Remember to let carpet dry completely before replacing it. It will be lighter when dry so easier to move. But as a glass on a wood side table leaving a ring a wet carpet can leave a shaped stain.
Jan 22, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
What are the different types of rugs?
There are three different types of rugs mainly available in three styles traditional, contemporary and transitional. Know more ec5a6c40-23e0-4023-80d6-64e06352c07f.jpg
Oct 17, 2014 | Home
After washing bathroom rugs, my Frigidaire Affinity front loading washer would not drain the water out or refill with water
Often washing things like rugs and matts can cause real problems for the drain pipes on you machine. Have you tried clearing out the drain plug, located at the bottom of the front of the machine? If that doesn't work, the whole drain hose from the drum will be blocked.
thanks
www.recycledrum.com
Jan 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Where can I find large cheap rugs to go in my apartment?
Rug is a floor covering, smaller than a carpet and made of thick wool or of other material, such as an animal skin. Rug will increase the decorative view of your house. If you want to buy rugs for your house you need not go to market. You can buy it from onine. Because most towns have stores that deal in overstocked goods or surplus. So you should buy it from online shop. If you want a cheap and large shop go with my link of Dallas rug. It is one of the biggest rug provider company. you can also visit their outlet. So hope for the best.
Nov 26, 2012 | Nokia Cell Phones
Washed a bathroom rug, which fell apart in the
The little pieces off of the bottom of the rug are clogging up the pump. Clean out pump.
Jan 15, 2010 | Dryers
Washer keeps beeping Fl
Your pump is clogged , It is a very bad Idea to put rugs in that machine either to fibers or the backing on the rug gets stuck. I hope you know someone handy. take out as much water as you can from the top with a cup or something. You are going to have to go under the bottom of the machine remove the 3 screws on the bottom plate. the pump is on the right you have to disconnect the black and the yellow hose very slowly there is a lot of water that you can't see from the top . then take down the pump and clean it out . Good luck remember no rugs.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
Small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
Nov 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
Walking Washer
Front loading washers do not do well on the new "soft" flooring that is installed in so many homes. We placed a thick commercial style rug with thick rubber backing all the way under ours which was sitting on Pergo and it stopped the problem. This wasn't my idea, it was what the repairman told me AFTER a service call! You should be able to purchase such a rug at a hardware store or a large department store in a small size. The rug just needs to really stick to the floor.
Good luck to you and Thank you for using Fix Ya!
Aug 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal De
