Question about HP Compaq Presario V2000 Notebook
WONT START UP
ONLY HAD IT ABOUT A MONTH TRIED TO TURN IT ON TODAY AND NOT HAPPENING IF IT STOPS RUNNING THREW CHANGING INVAILD PASSWORD TO DEFAULT ITS SAYING SOME THING ABOUT CHECKING DRIVERS FOR CONSISTANTCY OR IT HAS A BLACK SCREEN
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
Driver consistency check are nothing to worry about we all get them too. you migh have accidentally typed the wrong password. try to reinstall windows.
Posted on Dec 03, 2008
2011 Suzuki GSX-R 1000 L1 Key inserted, click on ignition, light dims but does not start, a random problem not always
Sounds like there is a short in the ignition wiring 12v side or ground side, check your contacts with a miltimeter and the next time it wont start try jumping the starter to your 12v switched source, bypassing the ignition, It the starter making noise when it does this?
Jan 14, 2014 | Suzuki GSX-R 1000 Motorcycles
The date will not set unless I use the default date. The time is set but the date will not. is there a solution to this?
Eureka! I was having this problem too! try using european format - day then month... when at default date you can't tell what format it is in so when trying to program it wont take an incorrect date (today is the 19th and I was trying to put that in the month field, invalid date so no dice) once you enter it you can change the format to whatever you prefer...
Sep 14, 2011 | Canon P200-DHIII Calculator
I have the first firefly phone from att&t then cincular i am needing to reset password and don't remember the code to do that.
For the Original Firefly Phone:
The default PIN is: 1 2 3 4.
For the glowPhone:
The default Password is: 0 0 0 0
When you first set up your password, you will be able to change from the 0 0 0 0 and enter your own.
If you should happen to forget what password you entered, you can enter the bypass password: 5 6 7 8 and this will then allow you to go into Parental Controls and change your password:
- Scroll to and select Permissions
- Scroll to and select Change Password
You will be prompted to enter a new password, then reaffirm it. You will get a confirmation when the password is successfully changed.
For the flyPhone:
The default password is: 1 2 3 4
When you first set up your password, you will be able to change from the 1 2 3 4 and enter you own.
If you should happen to forget what password you entered, you will need to follow these steps:
- Turn on your flyPhone
- From the Main Firefly Screen, you will need to type in the following (once you start typing, the screen will change): #20070330#
This will restore your flyPhone back to the default settings, so you can now go back in and reset your password.
or try this:
How can I change my phone's Password/PIN? For the Original Firefly Phone:
- Press and hold the green SEND button until you see ENTER PIN. Press Enter.
- Enter your PIN Number by scrolling though and accepting the four numbers you choose. (The default PIN is 1 2 3 4).
- Scroll to DONE and Press OK.
- If your PIN numbers are accepted, the display will say Change PIN.
- Press OK to let Firefly know that you do want to change that PIN.
When the display panel says SAVED, your new PIN is loaded.
For the glowPhone:
For the flyPhone:
Hope this helped.
Source: http://www.fireflymobile.com/
Jan 05, 2011 | FireFly Cellular Phone
Two months ago, after a couple of days of being parked, my 92 240 wouldn't start. my mechanic ran a diagnostic and ended up changing the spark plugs. come today, and again after sitting for a couple of...
About the only thing within time that can change from sitting that would effect starting performance is the fuel. The fuel is probably evaporating from your lines and other areas of the system.
Try turning the key to start with a pause till you hear the fuel pump stop, THEN turn it to run.
Jan 03, 2010 | 1992 Nissan 240SX Fastback
I NEED HELP RESETTING VM PASSWORD
Are you trying to enter the VM system by using FEATURE983?
When you have 3 digit extensions, you need to use 102 like you have tried. The password part of the login is the 0000. Someone must have changed it from the default 0000 to something else. Try 102**** where the **** is some other common password that you might use such as 1111, 2222, 1234 or others like that.
Jul 24, 2009 | Nortel T7316E 2-Line Corded Phone
I have a 2004 volvo s60, a few months ago I drove
change battery cables.if your battery over 5 years over replace it.i had same problem with batteries after 5 years .i am looking at starter you replace starter relay . but the starter could have a open circuit.take it off have it tested at auto zone or advance auto. they wont charge you to test it.
Apr 24, 2009 | 2003 Volvo S60
Honda element will start but sometimes wont idle
I have the same exact problem. Were you ever able to fix it?
Mar 19, 2009 | 2004 Honda Element
HP Compaq Presario V2000 Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
