Question about Zenith IQB36B42W TV
V chip plus turn it off
How do you remove the block once turned on by daughter playing with remote and activating the block and didnt have any idea what she was doing. Thank you Gerry
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
I bought rock band 3 for wii. I plugged in the dongle for the keyboard and followed the sync instructions exactly. the lights flash on both devices, but when I let go of the sync buttons, the lights on...
This can be frustrated the first few times. Here's the likely issue: the wii version will not activate the keyboard (or drums) if multiple wii remotes are active and all-instruments mode is not enabled.
The multiple wii remote thing: one remote is considered the microphone, and the rest guitar controllers (you can use the wii-remote based wingman and guitar hero guitars with this title). Once you get to two plus wii remotes on, you can't add more.
So, assuming one of your guitar controllers is active, use it to go into the menu system and turn all instruments mode on. Once done, a wii remote is no longer needed to be used for singing, and now singing will be turned on by default (but you can ignore it). Now, your drums and keyboard should work fine.
Eventually, the game smartens up and turns on this mode automatically for you, but the first few times it does not. I nearly threw the game out the window the first day or so.
Dec 31, 2010 | Rock Band 3 Wireless Keyboard
My daughters 2005 Ford Taurus went dead after leaving her lights on accidently after only 10 minutes. Someone jumped her and all was well. Since then ,every once in a while, ALL of her signal/trouble...
if lights flattened battery after 10 mins then its a new battery as no reserve amperage ,as for the lights on the dash i have no idea to be honest without a play with it
Nov 30, 2010 | 2005 Ford Taurus
Subwoofer in my truck will not play
you may want to check your grounds, your remote and of course the battery terminal. it seems obvious, but many times small things can cause big problems.(i.e. try cleaning the battery terminals)
Dec 02, 2008 | Car Audio & Video
Had a universal remote for my symphonic wf2703 tv my daughter tryed to change something with the remote now plays the dvd player ok turn it off all that comes up is a black screen with video on it the...
I had to clean the sensor area for the remote on the tv somehow got something on it. I wonder how, my little 4 yr old daughter had know idea how it got there lol.
Aug 01, 2008 | Televison & Video
I have a toshiba tv model:19a21 and i want to unlock the v-chip. i did not activate the v-chip i was like that when i bought the tv what can i do to reset it
To reset the V-Chip on the Toshiba 19A21:
Hold the volume down on the TV - at the same time, press the number 1 on the remote. The TV will turn off and reset everything.
Jun 22, 2008 | Toshiba Televison & Video
V-chip code
hav eyou tried to go into the menu or is this all that happens
shad
May 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
LOCKED HITACHI TV
need model and chassis number and I' may help you email me
Mar 20, 2008 | Hitachi C21RF39 21" TV
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
I forgot password for V-Chip / reset V-Chip
my brother greeting from belize lift the eeprom from out of the set and and resolder it back, it will have reset it self good luck.
Apr 03, 2007 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
Zenith IQB36B42W TV Logo
18 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
