Question about Achiever CCS5000 Shredder
Noisey Shredder Hi there! My shredder makes a noise whenever i am shredding. Can u please tell me what could possibly be causing that?
  • 2 more comments
  • fixbob Nov 05, 2007
    I have two of your (Model E160107 CCS/5000 SHREDDERS) both areidentical.
    When I turn them on they squeal.
    I have oiled then but they still squeal. Can you tell me how to fix then, or the price for the parts??
    Frank
  • HelptheYMCA Dec 07, 2007
    I own a CCS5000 that is very noisy and locks up after shredding one/two pieces of paper. Is there any hope for this machine? I've tried oil and cleaning . . . it still doesn't work. Help.
  • golfman16 May 22, 2009
    Tried oiling and cleaning. Neither worked. Any ideas?
  • Anonymous Mar 21, 2014
    won't shred. keeps on making noise but paper doesn't exit
  • 328 Answers
Have you oiled the blades? When was the last time it was serviced? There is an awful lot of paper shredds inside the unit. Motor bearings need lubrication. Gears need grease, etc. Put about a dozen drops of light oil directly down into the cutter left to right every half inch. I have used vegetable oil in a pinch.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jul 31, 2007
Clean out paper shreds - oil unecessary Manufacturer of Achiever CCS-500 new name Homeland Security Cameras (p)800-678-5891
Posted on Aug 22, 2007
The shredder is making a loud sounds and its stops midway while shredding.
Hi....I think I can help you with this. Since a particular model wasn't mentioned, I'm going to assume its a typical small office shredder. Shredders are generally not the quietest, but if it sounds more abnormal than usual, it's likely a hard or metallic item has gotten into the shredder blades and the shredder is struggling to overcome it. You can try to reverse the shredder and see if the shredder will back out the item. If that doesn't work, UNPLUG the unit and perform a visual inspection to locate the item and remove it.
The reason the shredder is stopping midway through, is likely due to excessive amounts of paper being fed into the machine at one time. This slows the shredder and overheats it. Your owner's manual will tell you the maximum amount of sheets that can be fed in at one time. Generally, it's about 5 sheets maximum. Trying to shred thick, un-opened letters/mail will also cause the machine to slow down and stop. If you have large amount of shredding to do, you might want to consider purchasing a more industrial type of shredder than your current one that will meet your needs.
I hope this has helped you.
Feb 05, 2016 | Shredder Office Equipment & Supplies
Keeps stopping with overload light on. How can this be fixed
The most likely cause is that the shredded paper, has tightly wrapped itself in the blades. One possible cause is by shredding labels (like Avery Labels) or any paper which has adhesive on it. (Causes it to attach the cut pieces to between the cutters.) It reaches a point where there is so much bound up on the blades that even a single sheet of paper will cause an overload. The fix is simple to describe, but difficult to accomplish. You must go in and manually remove all of the paper bound up in the blades. It's not easy, I found that using a needle nose pliers worked best. Lot of digging and tugging (paper will pack between the blades very tightly). Sometimes a small, slotted screwdriver will aid in being able to pry out bits and pieces (it's not going to come out in anything but small chunks; at best). Don't forget to unplug your shredder before you start; those blades are sharp. This happened several times with my last shredder *Royal), but not once with my current shredder (Fellows). I tend to believe that the better quality shredders are worth the extra money. But any shredder will become a problem if you shred labels (like Avery) or paper products that has adhesive on it. (Another common mistake is shredding junk mail that has any kind of adhesive associated with it. Best to open and check first.) One other thing, ALL shredders need to be oiled on a regular basis. They make special oil for this, you can usually find small bottles of it at Wally World or the like. Best practice is to squirt some shredder oil in a serpentine pattern. over a piece of paper to be shredded and run it through. Do this whenever you empty the shredder bin. (Important for the life of your shredder.)
Aug 29, 2014 | Royal 150MX Cross-Cut Shredder
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
Shredder OM02750 from Office Max..we have been using it a lot recently and it makes a loud screeching noise when shredding and after shredding that it did not make before. We have used the lubricant...
I had the same problem with a similar type shredder. Unfortunately, the only solution I could come up with after doing a lot of research and trying several diferent things was to buy a new one... good luck
evary at calgary dentists
Sep 24, 2011 | OfficeMax 0M96431 Shredder
I have a Royal Orca 9512x paper shredder. When I use it , it makes a very loud ,metallic squeeking sound. How can I correct this? It shreds fine. It's just noisey.
To fix this get some dry Graphite spray lube....
Spray graphite
Spray this on the cutters and sides of the cutters to lube the cutters and bearings....this will stop the noise...and prolong the life of the machine...
heatman101
Jun 18, 2011 | Royal 15MX Shredder
Good morning-my P50CM shredder motor seems to be working fine (same noise as usual) in both forward and reverse, however it wont accept paperfor shredding .I have removed as much cut paper between the...
You shredder needs a new shredding head. I'm sorry to say. You will be better off getting a new shredder. I am a senior level shredder technician in CO. I have seen this problem many times and it is an expensive repair. Hope this helps. If you have further questions please respond.
Aug 25, 2010 | Fellowes P50CM Shredder
Shredder does not pull paper in anymore, it makes noise, does not shred
Add some paper shredder oil. A shredder needs oil to function properly, oil should be applied every month or more depending on how often you shred. Learn more here: http://hubpages.com/hub/Paper-Shredder-Oil
Jun 13, 2010 | Fellowes DM8C Cross-Cut Shredder
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF1000MX Shredder
Shredder makes a horrible sound when shredding.
Just put a lightweight shredder oil on some paper and shred the paper...do this a number of times this will get the oil down into the cutting shafts.
May 01, 2009 | Royal VF1000MX Shredder
Paper shredder not working
sounds like the cutting wheels have something jammed inside them , can you take it bak and return it ? or open it up and see if anything looks bad inside ?
Jan 07, 2009 | World Office Products Papermate PM-600C...
Achiever CCS5000 Shredder Logo
545 people viewed this question
Top Achiever Office Equipment & Supplies Experts
Marvin
Marvin
quennie732
Cosmas Matanda
Cosmas Matanda
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
