Question about V.Smile V Smile Console
Power won't come on
My son was playing his Vsmile game when I was not in the room. He attempted to change the games without turning it off, I think. Now the power won't come on. I've tried it in several outlets and even changed the battery backup but nothing is working.
  • 1 more comment
  • jjkepka Dec 24, 2008
    I can't get mine to power up either. With the power off I hold reset/power then plug in the power. I can get a faint blue screen where you can see the "ec" from vetech (barely). ONce I insert a catridge all video is lost. Help!!
    This is an older V.Smile before the microphone was introduced.
  • mchll_hll Jan 10, 2009
    My daughter changed her game and when she tried to turn it back on it won't come on now. I use the ac adapter so i know it's not that the batteries dead so what else could it be
  • melba wright May 11, 2010
    did u take battery pack out and leave without power from electrical socket or the battery? if not do this let stand alone without power access for at least 24 hours. then reassemble.
This is a problem with the cartridge not the console. The cartridges get dirty and then the console acts as if its broken because it can't read the cartridge. Pull the purple flap up so that you can see the inside of the cartridge and clean it with an alcohol based cleaning solution. Dry the cartridge fully before inserting it back into the console. I have done this for serveral games and they have worked again. A couple of games have just broken and refused to clean up. Hope this helps, let me know.
Posted on Feb 28, 2009
Each time my kids try this, I take out the power cord from the back of the unit, replug it in, turn on the console to check that it is working, turn it off, put the game in, then turn it back in.  This seems to solve the issue for us.
Posted on Feb 19, 2009
When i plug in and turn on without a game in it, the v tech display comes on so system is working. but as soon as i put a game in it(3 different games) the game doesn't come on. i've tried putting game...
you have to do this in the right order or it doesn't work. Start with the TV and Vsmile OFF
step 1) put the cartridge in and make sure it is all the way in
step 2) turn the TV on
step 3) turn the Vsmile on
if it still doesn't work, unplug the adapter or take the batteries out and let the system clear and then do the steps over. Good luck!
Nov 27, 2010 | Vtech V.Smile TV Learning System
My xbox 360 turns off whenever i play a game. We have two xbox's and one turns off very quickly when playing games, and the other turns off after about 10minutes of game play. This happens with all...
There could be several causes. If you’ve managed to run other appliances with the same voltage through these power outlets without them turning off then it won’t be the outlets themselves.
It could be the power cable; try swapping them to see if this affects the frequency (10 mins vs ‘very quickly’). If this makes no difference then it won’t be them that’s at fault.
The most likely cause (unless both are simply faulty) is overheating. The Xbox 360 produces a lot of heat and there’s a failsafe built in to turn it off immediately if either the fan is malfunctioning or it’s too clogged with dust to ventilate properly.
Make sure nothing is sitting on top of them and that all ventilation areas are clear. If you think there’s a chance they might have become dusty, get a can of compressed air to dislodge any built up dust in the vents & a vacuum cleaner to remove it.
Oct 09, 2017 | Microsoft Xbox 360 Console
We have a vtech vsmile and it will not work correctly!!! it will turn on with no game in but as soon as you put a game in to play...it goes blank and will not play the game. It won't even let you turn it...
We had the same problem. Put alcohol on a q-tip. Pull back the plastic sleeve on the Smartridge (game) and clean both sides
of the metal contact. Insert the Smartridge into the Smartridge slot and remove quickly. Then insert Smatrige and turn on the power.
I did this to all of the games and now it works like new!
Hope this helps!
Jul 02, 2010 | Vtech V.Smile Pocket
We think a neighbor girl spilled liquid on/in my son's DS Lite. It now won't power on and the orange light will stay on for only a minute or two when we attempt to charge the unit. The battery is good......
If the DS was turned on when the liquid was spilled on it I don't think there is much hope to be honest:(
If it's under warrenty send it back otherwise you might try taking it apart and use a hair dryer to dry it off... that's a long shot though!
Jul 07, 2009 | Nintendo DS Lite
Sound
Have you checked the game settings themsleves? My son accidentally turned the sound off within the game while he was playing. Frustrated me for DAYS!!!
Apr 25, 2009 | Vtech V.Smile TV Learning System
Our Vsmile won't play
Make sure the system is off before inserting any cartrdiges. Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Dec 31, 2008 | Vtech V.Smile TV Learning System
Vsmile game unit
Try cleaning the contacts on the games. Push back the sleeve on the game and clean good with alcohol. If this doesn't do it, unplug it, and clean the contacts inside the unit with a qtip.
Hope this helps!
Nov 30, 2008 | Vtech V.Smile TV Learning System
Vsmile will not turn on
HI! Have a few ideas for you. First, are the batteries brand new never used good batteries? Also, are you sure they are in the correct way? If so, try to reset the system. Unplug all cords from the Vsmile. Then, for a full timed minute, press down BOTH buttons on the front of the console. After the minute, plug everything back in and try to power it up. If this does not work for you, please contact Vtech Customer support. You can reach them at 18005212010. Hope you find this helpful! Good luck! :)
Sep 08, 2008 | Vtech V.Smile Pocket
V.Smile V Smile Console Logo
707 people viewed this question
Top V.Smile Toys Experts
Andrew Taylor
Andrew Taylor
Are you a V.Smile Toy Expert? Answer questions, earn points and help others
