Question about Kenmore 63942 Dryer
Dryer does not give heat
My dryer starts but there is no heat
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
Dryer does not heat correctly code F31
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Dec 05, 2013 | Kenmore Dryers
My dryer heats up but then cools down right away. I got the top off the cabinet, turned the breaker back on. start the dryer and you can see the heater turn red and give out heat for about 30 seconds and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Apr 26, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore 80 series dryer starts(runs) but will not give off any heat?
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 07, 2010 | Kenmore 65924 Electric Dryer
My frigidaire gallery model fsg748gfs gas dryer starts to heat up but stops after a few minutes?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire FGQ332ES Gas Dryer
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
heatman101
Aug 22, 2010 | Frigidaire Dryers
I have a Maytag gas dryer, model MDG308DAWW serial 10578801GP. The dryer will start and heat up but after it runs for a short time the burner goes out. I bypassed the thermo limit and the problem still...
heatman101
Aug 20, 2010 | Whirlpool GGW9250PL Gas Dryer
Dryer will start to heat but will stop heating after a while but will tumble. Why would it stop heating?
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 17, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Dryer won't start
have you left the unit unplugged for one night and tried to start??
doe sit make any humming noise when trying to start
Aug 25, 2008 | Frigidaire GLEQ642A Electric Dryer
I have a maytag washer/dryer single unit stacker that works fine except the dryer does not give off any heat at all.
Start with resetting breaker dryer tumbles with 110 but needs 220 to turn on element. If still no heat might have a bad element.
Jul 09, 2008 | Maytag Dryers
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
