Question about Texas Instruments TI-30XA Calculator
On the texas instruments ti-30xa i cannot write a formula
When i put in a number then the peranthesis the last number gets eraised i want to input a compound interest
4/e
Posted on Dec 08, 2008
TI-30Xa I need to compound continuously and cannot figure out the buttons to use
Write a formula for your problem than type it in using the appropriate keys.
Sep 17, 2013 | Texas Instruments TI-30XA Calculator
How do i find the exponential root using the TI-30Xa calculator?
Using logarithms. For example, if A ^ X = 2; then X = logA(2);
This calculator only works in base-10 logarithms or natural logarithms, you should use the base conversion formula.
logA(X) = logC(X) / logC(A).
May 02, 2011 | Texas Instruments TI-30XA Calculator
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
I have a TI -30XA calculator. Need a battery for it. What is the number of the battery? Thanks, Ed
The TI-30Xa uses two A-76 lithium batteries. Comparable battery model numbers include: Duracell® D357 and Eveready® 357
Sep 23, 2010 | Texas Instruments TI-30XA Calculator
How to make this operation in my texas instruments TI-30XA 3.55*10(to the 24)
Because this calculator does not allow you to enter formulas, you have to alter the formula a bit.
Instead of entering 3.55*10^24, enter (10^24)*3.55
Note: 10^24 is 10 to the 24.
Here is the procedure:
1) find 10^24. Do this by typing 10, pressing the yx button (which is right above the divide button), and then typing 24. Press the '=' button.
2) multiple the result by 3.55. Press the '=' button.
You now have the answer.
Nov 23, 2009 | Texas Instruments TI-30XA Calculator
Exponential Grwth Equation
Input in this order:
ON/C
1.0025
LN
X
12
Apr 16, 2009 | Texas Instruments TI-30XA Calculator
Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Jan 09, 2009 | Texas Instruments TI-30XA Calculator
Inputing Scientific Numbers
If you mean using the "EE" key it's straightforward.
To enter scientific numbers, enter the number, then press EE, then the exponent value. The TI-30XA will stay in scientific display until you "clear" or turn it off. It will also switch to scientific notation if you multiply big numbers that exceed the display.
E.g. Input 3, EE, 10, X, 3, EE, 10, =, gives you the answer 9 times 10 to the power 20. Press the "square root" key and you will get back 3 times 10 to the power 10.
You can mix entries too, e.g. 3, EE, 10, X, 2, =, gives you 6 times 10 the power 10....
Nov 29, 2008 | Texas Instruments TI-30XA Calculator
Ti-30xa
Display has gone....you will have to buy a new calculator, fortunately the TI-30XA is only $10-$15!!
Mar 13, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
360 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
