Question about Kenmore 53642 / 53644 Side by Side Refrigerator
My kenmore side by side is not cooling model 106.51574200
The ice and food is melting in my freezer
  • skille Dec 03, 2008
    Yes the compressor is running and the fan in the freezer and underneath
    are both running
    Rick
  • Ken Bledsoe May 11, 2010
    Is the compressor on? You should be able to pull unit out from wall and feel the compressor. They run kinda quiet so touch it if it is warm maybe a little hot then its running and the next step would be seeing it the inside fan the one in the freezer is running.
  • 306 Answers
Now that really helps the one of two things it can be is the freezer compartment has the coils up there. They are more then likely covered in ice. Ice insulates the coils as to keep air from moving across them to remove heat from system. So take the back panel off in the freezer compartment and notice the shape of the coils. If they have a lot of ice built up on them unplug unit and get your hair dryer out to aid in defrosting unit a little quicker. If the drain tube located in the middle is plugged up with ice take some table salt and pour on the top. Only a couple a table spoons would be enough. let me know
Posted on Dec 03, 2008
Kenmore elite refrigerator
where is the ice,is it on the food and shelves or is it on the back inside wall of the freezer?if it's on the back inside wall of the freezer you have a defrost problem,bad defrost thermostat,heater,timer or board depending on your model number,if it's on the shelves,door and food packages warm air is getting into the freezer somehow either from the door not closing or the door was left open,could have a bad gasket on the door,the ice chute door could be broke and not closing.let me know what you find and the picture shows a side by side but i'll need the model number too,if it's a side by side or freezer on the bottom the model number should be in the fridge section,on the right hand wall up near the ceiling,if the freezer is on top the number should be on the left side wall in the fridge section up near the ceiling.but with this hot wheather we're having if the door was left open this will happen,you can shut down the machine or unplug it,remove the food from the freezer and melt the ice with a hair dryer,don't do this with the machine running because the hot air will cause the same problem,after the ice is melted you can put the food back in and restart it.
Jul 20, 2013 | Refrigerators
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Have a Kenmore side by side model#363.58062893 the freezer side is cooling and making ice but the refrig. side is not cooling there is some cool air but not enough to keep food cool enough. Traci
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 17, 2010 | Kenmore Refrigerators
My Kenmore side by side Refrigerator Model No. 253.55679403 will not freeze or cool, ice is melting and food is thawing. Light comes on and I can hear a fan or something, but I'm n ot sure. Can you help?
if you hear a fan in the freezer section when the door is open. feel the bottom of the fridge for hot air blowing. if you dont feel any hot air at the bottom, the condenser fan is the problem. if you do feel hot air then you have a defrost issue.
Jul 24, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
Freezer cools to 10 degrees, refrigerator cools to 50 degrees
check if the fan is working and you are circulating air efficiently. You may check on the coils at the freezer if there are ice formation. I would suggest to have the ice melted by unplugging it and ensuring that all parts are ice free. Clean the unit while at it.
Jul 15, 2009 | Refrigerators
Ice on back wall but not freezing food and rattle noise. Moved all food to other freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
May 30, 2009 | Kenmore Refrigerators
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side Model # 59507992
the relay overload plugs into the side of the compressor. its a common problem make sure you get one that matches your model number. it will fix the problem
Nov 20, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
94 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
