Question about Kitchen Ranges
Error code 120 frequently - Kitchen Ranges
    Genius:
  • 1,011 Answers
Sir,
this is the dust problem i think... clean the whole machine it will be cleared.
thanks
good luck
Posted on Dec 03, 2008
  • 19,396 Answers
Can you tell me the make and model of the kitchen range please?
  • Ginko
    Ginko Dec 03, 2008
    If you get error 120 on a Bosch kitchen range that means that the control pamel checkup went wrong. It means that there is either a bad control board, or bad connection to the panel.
    If this happens when the control panel warms up, that is the reason.
    Unplug power cord for ten minutes, and leave the range to cool up, that should clear the error.
    If the error happens very often you will need to replace the control assembly.
Thoshiba e studio 120. What does error code H4 mean?
The Code H-4 Mean the copier needs to be reset. Also I have added a link to help you troubleshoot the copier.
Thread Toshiba studio 120 with error code H4
Mar 17, 2016 | Office Equipment & Supplies
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
Read error codes on LG TROMM WM1614CW
The PDF Owner's Manual from Product Support contains error codes. It is not the exact same model but frequently the same product line uses similar components with similar error codes. Its worth a look anyway. Hope this helps.
Jan 03, 2015 | LG WM Washing Machines
Error 120 code
To reset the SC code follow these directions:
Resetting Ricoh Savin Lanier Gestetner SC Error Code
Error code 120 is scanner home position sensor problem. If it's a recurring problem, here are some troubleshooting tips:
SOLUTION:
Turn the main switch off and on.
Check the wires between Home Position sensor and the SBU.
Fix scanner board or the SBU .
Check the wires between scanner motor and the scanner I/O board
Fix the scanner motor.
Fix the Home Position sensor.
Fix pulley, timing belt, the scanner wire,
Fix the carriage.
Jun 17, 2014 | Gestetner Office Equipment & Supplies
Frequently the car fails to start, I get a "fuel flow error" reading. after setting for at time up to an hour the error diplay goes away and the car starts. I am perplexed---Any thoughts? 1995...
I had the same problem "fuel flow error". Ford dealership could not figure it out. They said it was probably a bad harness.
I replaced the main engine computer myself (about $120 for a rebuilt one), and the problem went away.
Jan 18, 2011 | 1995 Lincoln Continental
My Samsung dishwasher has a error code 4E after i start it up could you please let met know what this means thanks
Most common error codes that are caused by installation errors are:
  • 4E. If your dishwasher is displaying error code 4E, it can be caused by the water supply valve. The water supply valve may be closed, or not fully open. Most water supply valves are not frequently opened or closed. Because of this, they may be difficult to turn. To make sure this is not your issue, turn the supply valve to the fully closed position, clockwise, and then turn the valve to the fully open position, counterclockwise.
    • Check your water pressure. Your dishwasher requires a minimum of 20 psi and a maximum of 120 psi.
    • Water filtration info.
Nov 14, 2010 | Samsung DMR57LF Builtin Dishwasher
Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Jun 06, 2010 | Canon iRC3100 Printer
Frequent machine restart
Hi
yes problem because of virus or ram. first you install any good anti virus (nod 32, Kaspersky or BitDefender) if problem contuses replace fan, at last replace ram...
Thanks
May 06, 2008 | Asrock P4I45GV R5 Motherboard
Kitchen Ranges Logo
18 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
