Question about Acer Aspire 3000 Notebook
Acer aspire wont boot after improper shut down
I was removing unwanted stuff from my computer and it froze so I just powered it off and now it wont boot up again. I've already tried F8 to boot from last known configuration, I also tried safe mode and tried system startup repair. Nothing works so far, I really hope someone can help me. any suggestions?
  • sntarrer Dec 14, 2008
    I should have been more specific in what i was deleting but I didnt delete a any system files...only a boggle game that i downloaded and some pictures. During the uninstall of the boggle game from add and remove programs the comupter froze. Like I said I powered the computer off and now it wont come back on. Are there any other suggestions?
  • Acer Master
  • 32,281 Answers
It appears that you deleted some systems files.
You have been unsuccessful with System repair, then you need to reinstall Windows plus all your device drivers (eg. video, audio,LAN etc.) and your programs. If you don't have these drivers then go to a working computer and download them from the computer's WEB download/support site.
You will most likely lose your data in the process of reinstalling Windows, if you are desparate to recover your data, then remove the hard drive from the computer and connect it to a USB hard drive adapter and connect it to a working computer's USB port, this computer will see it as an external hard drive, you can then copy your data onto a CD or USB memory stick.
Posted on Dec 03, 2008
  • Chris Hingee
    Chris Hingee Dec 14, 2008
    There is one last thing you can try, and if it does not work you will need to reinstall Windows, provided you can get your computer into SAFE MODE to do a System Restore.
    Try System Restore, select a restore date before you installed the boggle game.
    To get there go to Programs - Accessories - System tools - System Restore - Restore My Computer to an earlier time, select a date and restore.
    Sorry for being the bearer of bad news, this is part of the fun of owning a computer.
    My gut feeling is that your Windows is screwed and possibly been affected with a virus/trojan horse and the only fix is to delete the partition, create it again and format it (NTFS) and install Windows again.
Why can't the automatic repair option fix my acer aspire v5 can't repair pc
I assume you are talking about startup repair which fails no matter how many times you run it.
The most common cause for this problem is file system issues on the hard drive. This usually occurs due to an improper shutdown (by holding the power button down to shut it off or if the AC is unplugged or fails without the battery installed or when the batter has failed completely). The solution to this is to either use a Windows boot disk (with an external USB DVD drive) and perform a CheckDisk on it or take the hard drive out of the computer and attach it to another Windows computer and perform a CheckDisk on it.
The second most common reason this occurs is due to a failing hard drive. Hopefully you have your data backed up somewhere. You will need a new 2.5" SATA hard drive and the Recovery Disk Set for your computer from Acer if this is the case.
I hope this has been helpful. Good luck and remember - always back up your stuff (pictures, music, documents, etc) - the more important your stuff is, the more places you want to have it.
Dave
Jun 12, 2014 | Acer Aspire One Netbook 8.9" Notebook
Aspire5551 hangs at starting windows
Shut down, unplug, remove battery, plug in ,reboot. Try a system restore/recovery, use this procedure: http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Jan 15, 2013 | Acer Aspire 5551 Notebook
My laptop wont turn on
You may have a RAM problem. Try reseating the RAM modules, if this does not fix your problem, remove the RAM modules and take then to your friendly computer repair shop and get them to test the RAM for you.
Feb 06, 2012 | Acer Aspire 5520-5908 Notebook
Wont boot up after an improper shut down, how can i make it boot up?
Try tapping F8 while booting and go to boot with "last know good configuration" if that doesn't work hit f8 again while booting and go to "safe mode" and do a system restore :) hope this helps thanks
Dec 30, 2010 | Acer Aspire One 10.1" Netbook Computer -...
Acer Aspire One loops on start up screen. All it does is show the acer logo, then shows the ''windows was shut down improperly'' screen with all those options and then goes to the windows xp start up...
Try tapping F8 when the acer window shows, when it shows the muliboot option, scroll down to "Last Known Good Configuration" and hit enter. If it does not boot normally, you will have to get an external dvd drive and boot off the drive with a windows installation disc to perform a repair.
Jan 07, 2010 | Acer Aspire One PC Notebook
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Booting problem
You may have to boot from a CD and make a repair.
Once logged in the CD, choose repair option (Recovery Console), and type these three commands:
1) fixmbr (wait til it finishes)
2) fixboot (wait...)
3) CHKDSK (this will take longer than the previous two.
Your laptop may now boot normally. I think your laptop doesn't have an internal CD-ROM so you may use an external USB CD.
Apr 22, 2009 | Computers & Internet
Windows not shutting down
You could try unplugging your laptop and taking the battery out, wait a few minutes put the battery back in, then plug it back in to the wall receptable, if you were working on something you wanted to save when this happend it might not keep any of the information, you should be able to boot it back up normally.
Mar 12, 2009 | Acer Aspire 5920-6727 Notebook
Acer aspire one not booting
your laptop has been turned off without shutting down. all your laptops registries are probably messed up. the easiest way to do is to reformat your computer or restore it to factory settings. unless you have some important files that you cant afford to lose.
Feb 07, 2009 | Acer Aspire One A150-1006 Notebook
Not booting, then shuts down?
I had the same problem. The computer is getting to hot. I opened the case and removed and cleaned the fan. It was full of lint thus keeping the fan from cooling.
Dec 23, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 3000 Notebook Logo
205 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
