Question about KitchenAid KSRS25IL Side by Side Refrigerator
Ice machine works great, but will not dispense
Kitchenaid KSBP25FKSS00 Superba. Ice machine works like a champ. Ice will not dispense. No motor sound at all. Trap door opens when dispense lever is depressed, and automatically closes. Water dispenses fine. All lights on panel change correspoding to button pressed (crushed, cubed, etc.) With freezer door opened, depressing the "door switch" ? will turn off the freezer light. Any ideas?? Thanks in advance. Rob
  • Rob DiTusa Feb 02, 2007
    Thanks, I'll check it out this weekend. Rob
  • 237 Answers
I just repaird a unit with this same symptom. Yours may be the same. The plastic part that holds the switch was broken (pins). See the diagram at http://www.partselect.com/Schematics/Whirlpool/KAZVHYR3.gif Item 15 is the part. The switch sets on a coupld pins and the pins break easily, thus the switch falls off and the dispensor lever can't operate it. If you look up inside with a flashlight you can see the switch, etc. and should be able to tell if it's held in place properly.
Posted on Feb 02, 2007
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side frig (KSCS25IN) will not dispense cubes
Check the drive gear for the agitator, It might have gotten stuck on ice too many times and stripped the gear. Good luck!
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Mar 23, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Not dispensing Ice or Water thru door
Found someone that was not going to charge me money for advice.
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba ice maker not dispensing ice
this is not a solution, but an explanation- our repair man said that there is a line (tube) containing electric wires that passes from the frig to the door at the bottom of the door, near the hinge. for what ever reason, the line has broken, thus keeping the electric from getting to the motor that dispense ice and water- solution= $700 for a new door; we'll do without
Sep 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
In door water/ice dispenser not working
check the connect part, see if the gears in the right position.
Jun 17, 2008 | KitchenAid KSRS25IL Side by Side...
KitchenAid Superba KSRA25F - makes ice fine - dispensing motor not working
Hello!
Please check the "Troubleshooting" part of the manual, especially the part "The water dispenser will not operate properly"
Hope it will help!
https://manualsbrain.com/en/manuals/1409170/?page=23
Aug 31, 2017 | KitchenAid (KSRD22FKST) Side by Side...
Icemaker overflows when filling
first, get your manual here:http://www.kitchenaid.com/custserv/service.jsp
The manual describes a wire arm which should gauge the amount of ice your unit produces. That arm is improperly set up or missing. The switch it controls may be defective. Have a look.
Dec 18, 2007 | KitchenAid KSRS25IL Side by Side...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
275 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
