Question about Toshiba Satellite M35-S456 Notebook
Laptop won't power up
Have a toshiba m35-s456 laptop. Just had the hard drive replaced. Now out of extended warranty. Clicked on a link on an item for sale on ebay, and screen got all funny, tan colored with red and green horizontal lines across it. Is the motherboard possibly gone again. Had it replaced 2 years ago, acted the same exact way. Try to restart and only shows power button lit, nothing on screen, and hard drive light glows showing trying to access it, but can hear it isn't spinning at all.
How hard is it to replace motherboard if i can find a doner system so i can sell this once and for all.......
    Problem Solver:
  • 6 Answers
Have you tried to start in safe mode? (hold the f8 key while booting). This will allow you to go back to a boot sequence that worked. You will need to go to start and select restore. Could be under accessories
Posted on Dec 03, 2008
The fan in my Toshiba Satellite M35-S456 not working
what is not working the fan or laptop?
when it stopped working the first time it is possible the laptop overheated and fried the cpu or motherboard. check the mother board and cpu for any physical marks where overheating has occured .
Aug 02, 2010 | Toshiba Satellite M35-S456 Notebook
I NEED REPLACEMENT BATTERY PA3331U-1BAS
Here is a link to a very good site where you can find a replacement battery for your laptop:
http://www.sparepartswarehouse.com/Toshiba,Laptop,Parts.aspx
Nov 16, 2009 | Toshiba Satellite M35-S456 Notebook
(Toshiba Satellite M35-S456) G-Force nVidia 5200 graphics card
To determine if your video card is faulty, connect an external monitor to the laptop, power up the monitor first and then the laptop.
The video data will automatically switch to the external monitor and if you see a normal image then the video card is OK and the fault maybe the video cable, it may need reseating.
If the image still has the strips, the same as the LCD screen then the fault is most likely the video card or video RAM..
On some laptops video RAM uses part of the main memory modules, reseat the RAM modules and if this doesn't fix the problem then the fault is the video card. This very difficult be fixed becaused it is part of the motherboard.
Jun 02, 2009 | Toshiba Satellite M35-S456 Notebook
Toshiba satellite m35-s456 my computer lights come on but it will not boot up?
The same thing happened to me today. I think it is the power supply connection to the mother board. I had to replace the motherboard 2 yrs ago with the same symptoms. I can reboot the computer 20 times and once the laptop will boot-up OK. But most of the time the power button will come one but the screen is blank. I'm not sure if I am going to get a new laptop or just replace the motherboard...again...
Feb 01, 2009 | Toshiba Satellite M35-S456 Notebook
Toshiba m35-s456 no power
To test if the adapter is faulty check it with a multimeter.
Test the output voltage on the connector that plugs into the laptop. The voltage should be 19 volts (the voltage is printed on the label on the adapter) or slightly higher because the is no electrical load on the adapter.
If there is no voltage or if the voltage fluctuates when you flex the power connector, then the adapter is faulty.
If the adapter is OK, then plug it into the laptop and the jiggle the connector a observe the charging LED light and if it flickers the fault is the power connector on the laptop. This can be repaired, it needs to be resoldered or replaced.
Jan 24, 2009 | Toshiba Satellite M35-S456 Notebook
I need the video drivers for my laptop m35-S456
PCs all use drivers for the various components they are designed to run or installed as an upgrade etc. Drivers are often updated during the useful life of the PC or device that is using the driver, so the best source is the manufacturer of the PC or the device itself. In your case Toshiba is going to be the best bet, even if you have your original restore disks the drivers contained on them may be outdated, or have issues the newer drivers were developed to fix. I have worked on a few Toshiba laptops including the M35 series, the drivers are available through the support link on their site, and with the full model # you should have no problem getting the correct one for your unit
Dec 03, 2008 | Toshiba Satellite M35-S456 Notebook
Toshiba satelite m35-s456 special edition
Is the blue line appears always or only in windows? If the lines appear only within windows then there could be driver related problem.
To make sure try to enter the bios when starting your laptop. If you cal see the blue lines there, then there is a chance that you have lcd problem
Nov 23, 2008 | Toshiba Satellite M35-S456 Notebook
Toshiba Satellite M35-S456 Notebook Logo
99 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
