Question about Brother DCP-7020 All-In-One Laser Printer
Changing drum After changing drum on mf7420 change drum message still appears
  • sespinal Jan 21, 2009
    the copier is saying that the drum needs to be cleaned. I cleaned it and it still says the same thing. the copies are coming out with big black smugges.
  • 624 Answers
Is this a brand new drum from Brother or is it refilled? When you inserted the new drum/toner cartidge assembly into the printer and before closing the front cover you need to press the "Option" button. You should then see "Replace Drum?" appear on the LCD. Press the up arrow key which should result in "Accepted" being displayed on the LCD. If you didn't do this give it a try and you should be good to go. If your still stuck let us know otherwise please don't forget to rate the post.
Posted on Feb 02, 2007
Please help replace new toner.. Cant close front cover
Posted on Apr 12, 2008
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
Change drum soon message won't go away after changing drum and toner. what do I need to do?
35YRTECH, aren't you being a wee bit flippant? I just changed my drum, had the same problem, and no where in mys instructions does it tell me how to inform the printer that I did reset the drum.
Anyway, here's how to do it (form the brother web site)
  • This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
    2. Press the Clear/Back key.
    3. Press 1 to reset.
    4. Close the front cover, pressing firmly on each side until they click into place.
Jan 07, 2010 | Brother Office Equipment & Supplies
Message reading change drum soon permanently on screen. changed the drum as no printing could be seen, ie paper blank. however, still got the change drum message on the screen. how do i get rid of this?
7 Wait until the time, date and answering mode appear on the display. Then press the SELECT FUNCTION key. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 8 Press the 7/COUNTER DISPLAY One-Touch key. The display will show DRUM COUNT. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 9 Press 2.413c?openelement&fieldelemformat=gif to clear the image drum unit
counter. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 10 Press the SELECT FUNCTION key to finish. ecblank.gif
Dec 03, 2009 | OKIFAX 4500 Plain Paper LED Fax
"DRUM LIFE OVER" KX-FL511
just change with new drum and toner.after replacing when msg gone just press start.u will receive ur faxes in memory.MIAN AKHLAQ
Dec 31, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
"Please change PC Drum" message appear on printers LCD
If your print job prints ok, ignore it. Just bear in mind you'll need a new drum soon. The drum is a light sensative roller that ink from the toner cartridge adheres to where the laser hits it. When it is no longer magnatized enough to hold the toner you'll see your print jobs start to lose that toner color. Just pull the drum out, buy a new one and put it in. Just don't expose the drum to light very long.
Oct 24, 2008 | Minolta Di2510 All-In-One Laser Printer
"Change Drum Soon" Message; not change when we changed the drum.
Description:
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Continous 'change drum soon' message after I change the drum.
5750e fax machine: To reset the drum counter follow the instructions listed below :
Get the message to appear in the LED
2. Remove and Re-insert Drum/Toner unit
3. Press the CLEAR key.
4. Press 1 to reset.
5. Close the front cover, pressing firmly on each side until they click
into place.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007572&Sympt=Why+does+the+message+CHANGE+DRUM+SOON+continue+to+appear+on+the+LCD+display+after+I+replaced+the+drum%3f&Model=58&ProductGroup=2&Keyword=Change%20drum%20soon%20message&ProductID=PPF5750e
Jul 08, 2008 | Brother Office Equipment & Supplies
Changing the drum
I fixed the problem (following the user's guide).
1. After reinstalling the new drum unit into the printer, keep the front cover open.
2. Press "Clear/Back" on the machine
3. Press "1" and when the LCD shows "Accepted", close the front cover.
May 14, 2008 | Brother DCP-8040 Copier
Drum on Brother MFC-7420
Why does the message "CHANGE DRUM SOON" continue to appear on the LCD display of my Brother machine, after I replaced the drum? Description: This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below. Open the front cover. Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO". Press 1 to reset the drum count. Close the front cover.
Jul 27, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
144 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
