Question about Aqua Brass Akro Shower Kit #2 AQUA BRASS AKRO-KIT2-BN
Temperature control knob fell off
The knob fell off and we don't know how to get it back on
  • 101 Answers
Hi welcome to Fixya.com
There should be a cap in the center of the knob that comes off and a screw in the center,...or there is a small set screw in the bottom it looks like a small hole and there is an allen key that is used to tighten ,you will have to loosen the set screw to put on ..then retighten.
Posted on Dec 17, 2008
Where is the air and heat blend motor on a 2000 dodge dakota?
Hi Sharon, I'm glad to help. Your 2000 year doesn't have a motor for the temp door. It operated by a cable running from the control head to the temp door and you work it manually. If you can't control the temperature from hot to cold, sometimes the cable come off or breaks. Here how you can see the cable to see if its working. Remove the radio and right behind it you will see the cable attached to the door, while watching it move the temp lever from hot to cold and watch it. If it is moving then its most likely out of ajustment. If it is not moving, then you'll need a new cable. Just in case it is moving, I'm attaching the instruction on how to adjust it below. Hope this helps and have an awesome day Sharon!
TEMPERATURE CONTROL CABLE
Any time the heater-A/C control or the temperature control cable are removed and/or replaced, the following procedure must be performed.
  1. The temperature control cable housing and core must be installed at both the heater-A/C control and the heater-A/C housing ends, and the heater-A/C control must be installed in the instrument panel. See Heater-A/C Control and Temperature Control Cable in the Removal and Installation section of this group for the procedures.
  2. Rotate the temperature control knob on the heater-A/C control so that the knob pointer is in the 12 o'clock position.
  3. Pull the temperature control knob straight out from the heater-A/C control base until the perimeter of the knob (not the knob pointer) protrudes about 6 millimeters (0.25 inch) from the face of the control base.
  4. Rotate the temperature control knob to the 1 o'clock position. Push in on the knob slightly and continue rotating the knob to its full clockwise stop. The knob pointer should be aimed at a position about 8 millimeters (0.315 inch) beyond the end of the graduated red strobe temperature control graphic on the face of the heater-A/C control base. If the knob is not pointed to the correct position, go back to Step 2 and repeat the adjustment procedure.
  5. Rotate the temperature control knob counterclockwise until the knob pointer is in the 12 o'clock position again.
  6. Push the temperature control knob straight in towards the heater-A/C control base until the perimeter of the knob (not the knob pointer) is flush with the face of the heater-A/C control base.
  7. Rotate the knob to its full clockwise stop again. The knob pointer should be aimed at the end of the graduated red strobe temperature control graphic on the face of the heater-A/C control base. If OK, go to Step 8. If not OK, go back to Step 2.
  8. Rotate the knob to its full counterclockwise stop and release the knob. If the knob springs back from the counterclockwise stop, the self-adjuster clip that secures the temperature control cable to the blend-air door lever is improperly installed. See Temperature Control Cable in the Removal and Installation section of this group for the procedures. If the knob does not spring back, the temperature control cable adjustment is complete.
May 14, 2014 | Dodge Dakota Cars & Trucks
The fan and temperature control knobs fell off my control panel. Need to know how to get them back on.
ask a mech, or DIY inclined friend, this is basics, there are no books for that.
we look at it, and see if its missing the clips or? and decide what to do. in most cases with a very old car the knobs are bad.
buy new ones. at honda. or off a wrecked car..
if above is too hard, then post a photo , of back side of know
and we can tell you why its bad. more are push on knobs.
rare are set screw type. (but is possible ) and varies by country car was sold,some countries use other HVAC systems.
and you never stated country. (fail)
Dec 13, 2013 | Honda Cars & Trucks
How to reconnect temp control knob 2001 ford escort
on the bottom left driver side unplug the black circular module that controls the temperature disable your stereo to hook back up to the teeth on the knob then feed the wire through back to where the module plugs in then put the stereo in the go under your steering wheel to the black module and plug it in now you have temperature back.
Dec 09, 2012 | 2001 Ford Escort ZX2
My older model electric hotpoint selfcleaing range, lower oven self cleaning function is not working. what could be wrong, maybe i didn't set a control knob correctly, don't have a maual for t
Back to the fifties! If the lower oven cooks normally, the heating element probably is OK. For self cleaning the normal temperature setting is bypassed and the heating element is set to a substantially higher level. Your oven may be unable to self clean because operation of the knob may not actually start the cycle. The thermostat could need replacing even though normal cooking is OK.
Sep 02, 2012 | Hotpoint Kitchen Ranges
How do i change heater control lamp
heater lamp- set the fan sped knob to #2 position, and pull the knob off. It might fight ya and you might have to use both hands... no joke. Once the knob is off you'll see the bulb in there. maybe it just fell out of the socket?? If you have it around, use a piece of vaccuum line, 1/4" I think to extract the little bugger
Dec 03, 2009 | 2001 Volkswagen Jetta TDI
Start knob fell off
order a new one from sears replacement parts
May 04, 2009 | Kenmore 43142 Front Load Washer
Temperature fault
Hi there, usually when those knobs fall off as long as you can guess where it would normally be, all functions work the same. In terms of falling off, they are made to come off for cleaning. Also, could I bother you, you dont have the manual for this oven do you? As we need a copy? Thanks a lot, Kerrie.
Sep 17, 2008 | Ovens
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Aqua Brass Akro Shower Kit #2 AQUA BRASS AKRO-KIT2-BN Logo
580 people viewed this question
Top Aqua Brass Home Experts
john h
Tom Chichester
Are you an Aqua Brass Home Expert? Answer questions, earn points and help others
