Question about Euro-Pro 8260 Mechanical Sewing Machine
Bobbin thread/feed dog eating fabric
I have a Euro Pro 8260 and when I sew with any fabric that is light weight, the bottom thread bunches and gathers and the fabric puckers. At this point, the needle is jamming up and the fabric is getting "eaten" from the bottom. This does not happen when I am working with heavier/thicker fabrics. I've tried cleaning out the bobbin case, changing needle sizes, thread type, tension, stitch length...I'm at a loss.
  • 1 more comment
  • Anonymous Jan 29, 2009
    When I start to sew on my Euro Pro 8260 it starts out fine,but if I stop in the middle of sewing something the bobbin thread gets stuck and starts to bunch up..and i don't have an owner's manual,am I not threading it right?
  • ccloonan Feb 09, 2009
    My problems is near the same. Sews fine for a while, then needle seems to get stuck in the bobbin/ feeder. Binds up the machine and the manual advance. I cant see what is going wrong but thread gets all bunched in the bobbin area. (sorry im not good with terms) Has actually broken two needles. (cleaned everything out, checked thread tension, foot, rethreaded bobbin with new thread, changed needle strength?) Im at a loss?
  • Anonymous Mar 17, 2014
    Is there a way of testing thread tensioner to make sure it is functioning properly while the top is removed?Recently had the tensioner rebuilt(so they said)and I am having stitch issues.The top and bottom are timed properly and am trying to work backwards to find problem.Machine is very clean,oiled lightly,etc.right thread,needle,bobbin case etc.Thank you
    Scholar:
  • 41 Answers
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
The cotton not bunching up in the bobbin case
Install a brand new needle.
Remove all the thread.
Clean the lint and debris from the bobbin area, feed dogs, and under the needleplate. Oil as (if) recommended in the manual--use only fresh, good quality sewing machine oil--and only 1-2 drops each place.
Always RAISE the presser foot when threading! Rethread from the beginning confirming the thread path is correct.
Set the upper tension to the midway point. The tension will probably need some tweaking to get it where it should be for your project. (Tweaking tension is a common & frequent adjustment to make, especially when changing projects using different fabric weights, thread, etc.)
Retest your machine.
If it is still globbing thread under the needleplate, you may need to take it for service.
Jun 04, 2016 | Sewing Machines
My euro-pro shark 8260 machine is stuck, even hand wheel does not move. can you please tell me how can i fix it?
Have you taken out the sewing plate and removed the feed dogs? Sometimes a huge knot of thread can get under there which disables the machine.
Best wishes
Aug 28, 2014 | Euro-Pro Sewing Machines
It bunchs up thread on bottom and stitch are to small
change the stitch length to about five
also change the needle
check to make sure the top thread has not come off the thread take up lever
also clean the bobbin area to make sure there is no lint or loose threads
also check the feed dog area for lint
Nov 13, 2010 | Euro-Pro 605 Mechanical Sewing Machine
Bottom thread bunchs up and feed dogs drop down
Check your manual and make sure the feed dogs are up/engaged to begin with.
Mar 18, 2010 | Euro-Pro 8260 Mechanical Sewing Machine
Thread jams
Hi! I've had this happen to me many times and it is so very frustrating! First, take the bobbin out and also the bobbin assembly and clean the entire area of all lint, fuzz, little bits of thread....get it as clean as you can. Take out the upper thread too. Clean and oil. Change the needle. Make sure you're using the appropriate size and type of needle and thread for the fabric. Take off the needle plate and look for any nicks or scratches. If you've got them, you can get emery cloth from a good hardware store (often in the plumbing department) and polish them out (or mostly out).
Rethread the machine, carefully following the instruction manual. Use your basic, normal settings. Using a scrap of the fabric you're trying to gather, sew a seam and see if everything works ok. You may need to hold the top and bobbin thread firmly behind the needle as you sew the first few stitches (I find this little trick helps a lot to prevent birdsnests).
To gather, sew three parallel lines of long, basting stitches (you really don't need a special foot or special settings other than to make the stitch a long one). Don't backstitch, reverse, or lockstitch either end, and leave the thread long when you cut it. Pull the three bobbin threads and the fabric with gather nicely along them.
Something to keep in mind--if you're trying to gather very sheer fabric on a zigzag machine, you may need to replace the throat plate with the zigzag hole for a throat plate with a single, small hole for a straight stitch. I've run into this situation before, and ended up using one of my antique straight-stitch only machines to do the gathering.
If you don't have a throat plate with the single hole, you might try some light weight interfacing to give some density to the sheet fabric.
Hope this helps!
Jan 31, 2010 | Euro-Pro Sewing Machines
Top thread gets stuck around bottom bobbin and jams machine
have you tried oiling it after you clean out all the dust and thread ends, you can take the feed dog plate off and clean under there as well. hope it helps
Jul 22, 2017 | Euro-Pro Shark 80 - 7133
Needle will not pick up bobbin threat
Try flipping the bobbin spool so the thread comes off in the other direction.
Forcing means that the needle has been jammed against the sewing plate ant the needle is now out of timing with the bobbin pickup.
May 31, 2009 | Euro-Pro 473
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
THREAD BUNCHING UP
there should be a small flat screw on the bobbin case that needs to be adjusted - turn to the left very slightly to weaken or lessen the tension and turn to the right very slightly to strengthen or tighten the tension. there may be two little screws in the same place - on my bobbin case, the screw to turn is the bigger one and is closer to the thread opening. hope this helps!
Apr 13, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing problems
For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
Mar 28, 2007 | Euro-Pro 8260 Mechanical Sewing Machine
Euro-Pro 8260 Mechanical Sewing Machine Logo
712 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
