Question about Home
Can't get the cartridge out of moen single knob shower faucet. Took off handle, sleeve and brass clip but could not pull out cartridge. Does it pull out screw out or what?
  • 33 Answers
You have a common problem with Moen cartridges. 1st if the valve is plastic these instructions may not help you, they are for brass valves. If your not afraid to spend a little money you can go to the local hardware store and ask for a Moen cartridge puller. They usually cost between $15-$100 for the good one. Get the one that looks like a tee. (see picture)
  1. First turn off the water to the valve.
  2. Screw the tool to the valve where the handle would connect to.
  3. Align the slots on the tool to the slots on the valve.
  4. Turn the valve 360 degrees several times.
  5. Pull the valve gently and firmly towards slowly increasing the pressure.
  • At this point the valve will come out and your done.
  • If just the center portion will comes out heres what you do.
  1. Remove the center portion of the valve from your tool.
  2. You will notice at the end of the tool handle is a brass ring.
  3. Slide ring down to button and depress button until it is held in place with ring.
  4. Slide this part of the tool with ring into the valve. (ring will not go in valve)
  5. Insert this into the valve all the way you can until you hear a click.
  6. Turn and gently pull until valve comes out.
  • Note: if both of these fail you need to change the valve.
Posted on Dec 05, 2008
I had the same problem. I purchased a Moen economy cartridge puller and it worked fine after I rigged a spacer sleeve over it. Brute strength just doesn't work once the cartridge is stuck.
Posted on Jan 13, 2009
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Apr 29, 2015 | Delta & Single Handle Shower Faucet
How to fix bathroom shower faucet
shut off water to shower, remove knob by popping cover off and removing screw, remove valve cover by just pulling straight out. there will be a retaining clip that holds cartridge in you will need to remove, Pull out old cartridge and replace with new.
Feb 21, 2014 | Moen 3175 Legend One Handle Shower Faucet...
Shower/tub faucet does not provide cold water, only to warm and hot.
The faucet has a cartridge that is dirty or bad. Turn off water to the house and remove the cartridge. Take it to Lowes or Home Depot and get another replacement. follow the instructions in the package to the tee.
The old cartridge easily pulls out after you pull out on a clip on the top of the internal assembly. Just take the handle off, slip out the chrome sleeve and remove the clip. The cartridge will pull out with minimal force.
Then head to the store!
Oct 13, 2010 | Moen & One Handle Tub & Shower Faucet
How do you remove the temperature knob and cover from a delta shower faucet, model 1824 (Monitor 18 series)?
http://www.deltafaucet.com/customersupport/documentation/1824-74.html?document=pd&documentIndex=0 The very center piece of the temperature setter pops off with a screw driver. Remove the screw underneath it and everything else to the handle comes off. Firmly grab decorative sleev behind handle and pull. Firmly grab round brass collar and turn counterclockwise. carefull pry cartridge from brass body.
May 22, 2010 | Delta & Single Handle Shower Faucet
I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
May 13, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
On my Moen shower facet
There is a small "U" type clip that comes down in front area to hold it in, I assume that has been removed. The new cartridge should have come with a small tool (usually plastic) that you put over the cartridge, push it in, and turn the body of the cartridge, and it should start to ride up on higher brass sleeve and start to pull itself out. If you look at vertical part of cartridge, it is sitting back in on low spot of the sleeve. That tool, or a pair of strong needle nose pliers,needs to be against the sides of the vertical part of the cartridge, in such a way that when you rotate the cartridge, it rides up on higher part of sleeve, and pulls itself outward.
Apr 16, 2010 | Moen & One Handle Tub & Shower Faucet
How do I remove cartridge from at least 20 year old moen single handle shower faucet. I have removed the clip and it still wont come out. Almost looks like it is not meant to come out by design. I am...
Use little tool (plastic) that comes with new cartridge, in center, and push in and turn with wrench on square end.
It has to bite in to cartridge, and as the cartridge turns, it will start to move outward. You'll see how sleeve where cartridge sits in, is shaped live a "V" sort of, and as the cartridge turns, top and bottom brass pieces of cartridge follows that "V" and lifts itself out, far enough to get hold with pliers, and wiggle and pull. Sometimes takes a little patience, and maybe the odd curse word, but should come out.
Jan 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
Home Logo
602 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
