Question about Polaroid PhotoMax PDC 700 Digital Camera
Polaroid PDC 700 memory card error message
I went to Flash memory store.com and ordered a card for the camera. It is 512 MB. The site info led me to believe the card will work but when I put it in the camera I get a card error message. Is there any way to use this card? Where can I get a card that I know will work?
According to the actual manuel and other info on this,  it will only hold as high as a 48x.
Posted on Oct 16, 2007
I cannot capture new pictures with my polaroid pdc 2030 digital camera . I get error message FUL when the shutter is depressed .
When you download does it delete the pictures automatically or are all your pictures still on it. It sounds as though the internal memory or memory card is full and you will need to delete some pictures or format the memory after you have downloaded them to your PC.
Jul 23, 2016 | Polaroid Cameras
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Memory card format.
The Polaroid PDC 700 digital camera accommodates an optional, Type 1 ATA compatible CompactFlash memory card up to 48MB. When an unformatted memory card is installed in the camera, it is automatically formatted when the camera is powered on. WARNING: Once you format the flash memory or format a memory card, all images are erased and cannot be retrieved - they are gone forever! Before you format (erase) the flash memory or format a memory card, transfer the images to your computer.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
ERROR: code 402 in LED panel
Error code 402 indicates an issue with the SmartMedia card. Make sure that the memory card is properly inserted into the camera. If the card is not the one that was originally packaged with your camera, check to make sure that it meets the camera's requirements. The PDC 640 digital camera accommodates SmartMedia cards at 2 MB, 4 MB and 8 MB capacities. If the condition persists after checking the above, the SmartMedia card may be faulty or corrupted and in need of replacement.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 M Digital Camera
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Memory card?
The PDC 700 digital camera has 4 MB of internal flash memory on which to store images. An optional ATA-compatible Type 1 CompactFlash memory card gives your camera substantially more memory, allowing you to store more images or images of higher quality. images captured on the CompactFlash card can be downloaded using the same method as you use to download photos from the internal memory.
Can I use a Polaroid digital camera as a web camera?
None of the Polaroid digital cameras listed below can be used as a "web cam." All of these models are designed for taking still images only. DMC/DMC 1e DMC2 Fun! Digital 320 Fun! 620 Fun! Flash 640 Fun! Flash 640 SE Fun! Flash 820 MP3 Digital Camera Olympus C-211Z PDC 300 PDC 640 PDC 640CF PDC 640M PDC 640 Plus PDC 700 PDC 800 PDC 1100 PDC 1300 PDC 1320 PDC 2000/3000 PDC 2300Z
Sep 14, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Can I use the PDC 700 camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will no longer be able to use a USB port to download your photos. Only serial port downloads are supported under Windows XP for the PDC 700 camera.
Sep 14, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Polaroid PhotoMax PDC 700 Digital Camera Logo
171 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
