Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
WD Passport drive unmounts itself when connected
Western Digital Passport USB drive loses connection. I have tried new USB cables, some USB cables work better than others none are perfect. It continues to drop the connection. The drive is on my desk and stable. The cables is not loose. Is it a problem with the drive or do I need a special cable?
Look up how to remove the drive from the enclosure on you-tube
it is easy and safe.
one of the removal videos also shows how to remove the USB-SATA adabter (it is really a sata drive). The removal is easy.. just pull it off.
You then have SATA ports.. just plug the drive into your computer through a SATA port and then you can access your data.
It is most likely the USB adapter that is broken (they break easily).
IDK if you can find a new one.
Posted on Dec 24, 2008
When I connect my wd passport, this massage appears "usb not device recognized". although the cable is working with other devices and the wd passport is also working on other computers (not my...
there is NO problem on you external hard drive..the problem is in your own computer USB port..try to uninstall the driver of your usb port.then try it again.
Jun 15, 2011 | Western Digital My Passport Essential 160...
When i connect my passport the computer recognizes it,but then it ejects itself form my computer. sometimes the start screen appears, then it ejects itself. please help
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 25, 2010 | Western Digital WD Passport 250GB Portable...
I have a 1tbexternal hdd drive and it stopped working. i tryed to switch the plug and put it on other computer but nothing.....
The Passport has four major components:
* the USB cable
* the power-adapter
Get the part-number and serial-number from the label on your disk-drive, and access the W.D. web-site, and use "check warranty status", to see if W.D. will replace the Passport, at minimal cost to you.
Nov 07, 2010 | Western Digital Passport 160GB External...
Why wont my Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive work?
Several possibilities:
* bad USB port in your computer (try another USB port)
* messed-up copy of Windows (try connecting to a different computer)
* damaged USB cable between computer and the Passport (replace it)
* bad disk-drive inside the enclosure (replace it)
* bad USB-to-disk-drive adapter (buy a new "empty" enclosure)
Check the warranty on it, to see if W.D. will replace it, at minimal cost to you. If the warranty has expired, W.D. has a "Customer Loyalty" program -- buy a new Passport through their web-site, and you qualify for a discount on your purchase.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
PC nor reading external WD (Western Digital) USB hard drive
Try connecting it to another computer, to see if your computer is the problem.
Try a different USB cable between the unit and your computer.
If it is still under warranty (one year?) then contact W.D. to get an RMA (Return Materials Authorization) -- then, ship the unit to them, for repair/replacement.
If the warranty has expired, open the case, disconnect the USB-to-disk-drive adapter, and connect the disk-drive as a "slave" drive in some desktop computer, to see if it can be properly "detected".
Note that W.D. has a "Customer Loyalty" program -- give them the serial-number from the disk-drive, and you get a good discount on the purchase of a new Passport from their web-site.
Jul 30, 2010 | Western Digital WD Passport 250GB Portable...
My computer does not recognize my WD external drive
You've tried different USB cables; so, that cannot be the problem.
You've tried connecting to different computers; so, the problem is _not_ your computer.
What's left is "inside" the case:
* the USB-to-disk-drive adapter,
* the disk-drive.
Open the case, and remove the disk-drive, and connect it as a "slave" drive to some computer.
If it is detected, then the USB-to-disk-drive adapter that has failed.
If it not detected, then the disk-drive itself has failed.
FInd the serial-number on the Western Digital disk-drive, and enter it onto Western Digital's web-site, on the "check-warranty" page. If it's older than 3 years, the warranty probably has expired, unless you were "lucky" and got a 5-year warranty.
Western Digital has a "Customer Loyalty" program -- just buy a new Passport through their web-site, and cite the serial-number, and you'll get a significant discount on _their_ price (could be higher than your local retail computer-store) for a new (probably larger) Passport.
Apr 05, 2010 | Western Digital WD Passport 250GB Portable...
Hi i have this "Western Digital WD Passport 250GB Portable" Problem Now! broken one of that pin where usb connect to hard dirve .
I did this once had to solder an interconnect to the other side of the connection of the PCB then use a small croc clip to make the other connection worked just fine just not aesthetic
Mar 21, 2010 | Western Digital WD Passport 250GB Portable...
Have a WD 250 GB and wont connect to Computer
It is the cable. Use an original western digital usb cable for this drive.
Mar 31, 2009 | Western Digital Passport WDXML800UE...
WD Passport appear as an unknown device
try it again, after going to wd dot com, and getting and installing a new set of drivers..
Oct 13, 2008 | Western Digital Computers & Internet
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
412 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
