Question about Kenmore Freezer 14.1 cu. ft. Upright Freezer with Hose Adapter
Temp alarm on freezer alarming.
I have a kenmore frostless freezer. Model number 2539280413. The temp alarm keeps sounding. I have turned the freezer to coldest setting, Worked for awhile the alarm came on again. Food within is frozen, the meat but the frozen burgers are alittle soft. Any suggestions.
  • Anonymous Dec 30, 2008
    I have the same problem the alarm is on what is causing and how do you stop it?
That's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Posted on Feb 25, 2010
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
I have a Kenmore Frostless Model #: 253.21041104 The temp. alarm keeps going off. The red light blinks and alarm goes off. Owners manual says that it is from warm conditions, but there are no warm...
Best thing to do first is get a thermometer to be sure the temperature is correct. Items still freeze at higher temperatures. If you have ice cream and it is soft, then you have a temp problem.
Jul 05, 2017 | Kenmore Freezer 13.7 cu. ft. Upright...
Older model frostless freezer model number 2539280411. The temp alarm light is blinking.
Is the temperature warmer as well, or is it just the alarm light blinking?
Nov 09, 2010 | Kenmore Freezers
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
Kenmore frostless 19 temp. control knob
i've pulled up the service diagram for it and there's no thermostat or temperature control but there's a limit sensor inside the freezer I'm sure that such sensor is failing and when it defrosts, it stays on to long, and the whole 15 min defrost cycles goes on causing the freezer to warm up, delaying the freezing process. I'm almost sure that the limit is going.
Jun 10, 2008 | Kenmore Freezers
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
1,909 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
