Question about Compaq Presario 5000 PC Desktop
CPU won't power up
The CPU does not power up with the power button pushed in. I removed the power supply from the chassis and power it up . The fan in the power supply did not come on.
Could a virus cause such problem?
Cyrus
  • calexander12 Dec 03, 2008
    I did not check the voltage I just wanted to know if the fans would work if disconnected from the chassis.
    What is the most likely problem? Is there a fuse in the power supply I I did not see? I do not have a schematic so I do not know where my 12 and 3 volts are on the harness but I can figure out the 5 volts.
    Could it be a shorted capacitor?
    Cyrus
    Since it would be cheaper to replace a fuse if there is one rather than the whole power supply, I would have like to have all my questions answered.
    Maybe I can fix the power supply with some prints.
  • Compaq Master
  • 19,396 Answers
The power supply does not come up if it is not connected to the motherboard, even if it is not faulty.
To test a power supply you should test the voltages out.
At the workshop we dont even bother in thesting them, if there is no power on motherboard , then we just replace them.
check if the motherboard is powered, using a Multimeter on the MB switch contacts, if there is no power , replace power supply.
Posted on Dec 03, 2008
    Sergeant:
    Champion:
  • 251 Answers
Power supply issue not nothing else buy a new power supply and it will turn on again there is a short in ur power supply
    Genius:
  • 1,011 Answers
Sir,
Replace the fan with new one it will solved the problem.
thanks
good luck
    Master:
  • 763 Answers
Sir, after removing the power supply did you manage to insert it correctly to the motherboard again? or the powersupply itself is the problem. if not then when this problem happen? can you give us a few details about this situation of yours. By the way, virus can disfunction the motherboard but not the power supply.
thank you for using fixya
CHARCOIS
    Genius:
  • 3,422 Answers
Please recheck all the connection, its a loose wire connection and not a virus issue. Please check wire connecting to UPS and to CPU and plug in properly.
    Scholar:
  • 61 Answers
Try a different power supply there is no virus to blow a power supply even if a harddrive isn't connect the cpu should still come on and if your not getting any power and hadn't changed anything on the inside like the connections to the mother board from the buttons than more than likly the power supply quit is the fan dirty on power supply if so than it has dust on components inside power supply that caused overheating....
  • 6,487 Answers
This can be a problem with the power supply of your computer and it will be better if you can try a different power supply so we can really check what is the problem here....
  • 837 Answers
No a virus would not cause the power supply to fail.
Are saying the power supply powered up when you removed it from the chassis but the fan didnt spin?
What makes 511-cpu fan not detected and 512-chassis not detected
Are you seeing this error on a system you built or a pre-built system? If it is a pre-built system, check that the fans are running. Next check where the fans are plugged in, the CPU fan must be connected to the CPU fan connector on your motherboard. The chassis (rear case fan) only needs to be connected to the motherboard if you want the monitoring/PWM (modulated fan speed) option. If your CPU fan is powered directly from the power supply, change this.
If this is a system you built or recently updated the case, check your fan power connections, as above. Next check the fan speed. My ASUS board will give the "CPU fan not detected" error if the CPU fan speed is too slow. A different CPU fan will solve the problem. (I got my fan with the CPU; it works fine.)
I hope this helps. Please add a comment with more information about your system for more assistance.
May 12, 2013 | Computers & Internet
I have a hp pavilion 742c monitor said no signal
Hello, please check the power connector of your CPU fan and chassis fan. Or try to check you power supply maybe it can't supply anymore. But I guess it's the power connector.
Oct 08, 2012 | HP Computers & Internet
I have ( IBM ThinkCentre 80847eg ) after starting power it shutdown automaticly after 30 seconds so i push power button again ,then it takes 3 minutes to get windows logo . so what's the problem
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 29, 2012 | Computers & Internet
Hp 300 12z. Desktop i relocated and plugged everything back in. I push power button and the fans start to run however after 45 seconds they shut off and screen goes black. What could be wrong.
Jul 07, 2012 | Computers & Internet
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Power supply has shutdown
It may not be the power supply.
Mar 06, 2012 | Computers & Internet
There is definitely a power supply problem with the Dell XPS 200 I have. It starts fine and runs beautifully for about an hour. Then suddenly the screen goes blank, the light on the power button flashes...
First ingeneers build things to fuction AS IS, so i'm not sure you need more fan power.
Verify the inside of the computer is the CPU heat sink (big aluminium block with fan) CLEAN of any dust? are all the fans turning correctly (resonable speed)? verify the placement of the PC itself is it cooked up in a cabinet or pushed against a wall (blocking the holes in the case for air intake)?
if all of the above is OK you could re-paste the CPU (spreading new heat sink compound between the CPU and the heat sink)
Dec 31, 2010 | Dell XPS 200 PC Desktop
I have a Gateway 507gr pc. Pushing the power supply button the fans turn the cpu light turn on and the pc does nothing else.
you'll need a good power source.replace the old one ; remove all conection from hdd ,dvd's etc..make sure you have a speaker on MB.remove all the ram you have and power on the pc ;you must here a long beep folowed by 2 short one's;if you don't hear it your MB or CPU are gone.But if you do hear then put back the ram and remove your video card and power up the pc again , you must hear a long beep folow by 3 short one ; if you don't hear your MB or CPU are gone but if you hear that means the power supply was the problem.
Apr 21, 2010 | Gateway 507GR PC Desktop
Friend has a Emachine T1862 that won't start
May be the CPU fan is going bad. I hope it is that simple.
Dec 14, 2008 | E-Machines Computers & Internet
Computer sometimes won't turn on when i press the power button
you are correct on one and two above, in your suspicions..how's your power from wall, and do you use a UPS?
check your computer warranty here 4 FREE
Feb 27, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
