Question about Panasonic Heating & Cooling
Panasonic air conditioner. Very small amount of water coming out of unit. There must be a blockage, were do I look for it and is it still ok to run unit? Split sysytem model CU-A24BKP5
  • 334 Answers
If you have a very low humidity level then you will have very little water.
You also may hav a partial blockage as you suspect.
Look at the bottom of the evaporator coil, locate the drain pan. if it is dry as well (or very little water) then you must just have low humidity.
On the lower corner of the pan is the drain, thats where the greatest potential for a clog would be.
If your unit is equiped with a hose, check the hose for blockages.
Posted on Dec 27, 2008
  • 306 Answers
It is okay for water to come out of unit unless if it comes into your living space. Then your angle of the unit is off and needs to be readjusted. lean the unit away don't have it level. Needs small amount of angle for excess condensation to run outside.
Posted on Dec 03, 2008
  • Ken Bledsoe Dec 24, 2008
    Did you get it taken care of gmoore629
When water runs off the condenser, is there a path it follows to the back of the unit that cold become blocked?
ac units are designed with a small trough at the back of the unit under the evaporator fins
this trough drains out a small hose to outside the building
It can become obstructed by gunk from the inside of the house ( same gunk that blocks the air filters) or the hose attached to the drain outlet can become blocked
check for a mud wasp nest in the drain hole as well
Jul 12, 2015 | Filter Heating & Cooling
Our whirpool split a.c. Is not dripping water
Hello, if the unit is not draining condensate then the line may be blocked Or the unit may be undercharged due to a leak. Sometimes if the humididty is not very high the unit will produce very small amounts of comdensate. Check the drain line first for ay blockages.
May 12, 2012 | Whirlpool Heating & Cooling
How do you drain water from a LP1010snr air conditioner?
P2 means the water collection tank is full and needs to be drained. You have to pull the drain plug at the bottom of the unit and drain the water.
Drain the water (small amount actually) in the shower. Note: There is a cap towards the bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine.
Apr 17, 2012 | Heating & Cooling
With the unit running, the unit sounds as if water is running. turned off and unplugged, the unit was tilted toward the drain . some water [ a small amount ] drained out. resumed running unit, sound of...
This is usual But be certian that the unit is tilted enough also check filter and clean it while your at it . then check drain . you might have some dirt around the drain . if so clean it and add a bit of clorox a tiny bit ony to the drain let me know
Jul 22, 2011 | Goldstar R5050 Air Conditioner
My split air unit is running inside and out but is NOT blowing any air at all?
Either the blower motor is not working or there is a blockage in the airflow. If you have no air movement in your vents then the blower is the most likely cause. If there is a small amount of air flow then a blockage is more common the cause.
If you suspect the blower motor then you will need to have the motor and the capacitor checked to see if either one or both of them need replaced.
If you suspect a blockage then cut power to the unit and remove the top. Check for a blockage at bother the evaporator coil and the condenser coil. Also check your blower wheel to see if it is in proper working condition. Hows your filter?
Jun 12, 2011 | Intertherm P3RC-042K Air Conditioner
The drain is blocked and water running out of the wall unit into the house. I have tried to get a hose into the outlet drain and blow up it, but the unit is too high on the outside wall for me to do that...
Drain blockage is the common problem. Drain block due to dust blocked in air filter,coil and drain pan. Call serviceman to service the unit completely.Helpful?
Jan 05, 2011 | Panasonic CS-A12C Air Conditioner
The ac is dripping inside the room
Hello.
You need to clean out the drain pan.Also unit shold be tilted back a little so water will run outside.
Remove the front grill and using an old tooth brush clean out the bottom pan where water is laying.Also be sure the drian hole outside the unit is clear.
May 27, 2010 | Panasonic CW-C100AU Air Conditioner
Why is water is coming into the room through the
Most probable cause is a clogged drain line or a drain that is not properly pitched. Ensure the unit is level and that the drain line is properly pitched and clear. Some units are equipped with a small condensate pump. The unit will leak water if the pump is not working properly.
Mar 01, 2010 | Carrier 36KCARMS Air Conditioner
Panasonic Inverter aircon E24DKR icing up inside unit
Yes, if the filters are clean, the coils are clean, and it is still freezing up in cooling mode, then it is low on refridgerant.
Jan 14, 2009 | Carrier 52PQ307 Wall/Window Air...
Water leaking from portable air conditioner
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Jun 13, 2007 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
143 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dan Webster
Dan Webster
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
