Question about Metrik Amplifiers MAX-1404 Car Audio Amplifier
The red led light on my mertik max-802 is staying on when i hook it up. the fuses are not blown out so wat could be the peoblem
    Problem Solver:
  • 22 Answers
Could be the ground. Or touching wires. if the speaker being hooked up are pulling the wrong ohmage it could also shut down an amp.
Posted on Dec 04, 2008
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
Mar 29, 2014 | Pioneer GM-5200T Car Audio Amplifier
2001 Mazda protege radio and lights in car not working after jumper cable s were hooked up backwards
Connecting jumper cables the wrong wat around most likely has damaged electronic components such as a radio and computer.
Check the fuse box and replace any blown fuses.
If you still have problems then get an auto electrician to fix your car.
Mar 06, 2013 | 2001 Mazda Protege
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
THE FUSES ARE NOT BLOWN AND THE FANS AND RED LIGHT COME ON BUT THERS NO SPEAKERS COME ON
first of all the reason why the speakers aren't working is because the red light isn't supposed to come on a green light is and if it is red that means something got fried or damaged
Jun 07, 2009 | Metrik Amplifiers MAX-802 Car Audio...
4x4 stick stuck , wont move
There is a small green 4x4 light that comes on when you have the key in at the heater plug position before starting if its not on then a fuse has blown .
Apr 13, 2009 | 2000 Isuzu Trooper
Help my MP4 players wont turn on!
Does the icons on the unit show if it's charging? If so the LED is on the charger is bad.
Sep 16, 2008 | Delstar DS-802 Digital Media Player
Red Led Light on My Bazooka Ela300.1
Your amp went into a " Protection Mode "
this happens if you have blown something inside like a IC or something... if the amp have been dropped or bumped then its very likely to happen ... Check and see if your fuses are ok, if not then it would be best to let it be checked by a expert if its a IC or a cap inside
Cheers
Dec 18, 2007 | Bazooka ELA300.1 Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Rt 202 led light red and no sound
With the system turned off, disconnect the speaker wires from the amplifier. Turn on the system. If the light stays red, then the amplifier has an internal problem. If the light turns green, then your problem is a blown speaker, or a speaker wiring issue.
Jun 03, 2007 | MTX RT202 Car Audio Amplifier
Metrik Amplifiers MAX-1404 Car Audio Amplifier Logo
Top Metrik Car Audio & Video Experts
xxxxxx xxx
Are you a Metrik Car Audio and Video Expert? Answer questions, earn points and help others
