Question about Sony Xplod (P589) Car Subwoofer
One hits harder then other
I have 2 12' 1200 watt xplods hooked up to my amp. they work fine, but one hits harder then the other. they are both the same sub hooked up the same way and everything. i had this happen before, and all asudden they hit the same but now they are doing it again?
  • 62 Answers
A faulty voice coil may be to blame on one of the subs...when it heats up it starts to act up leading to a undesired preformance.
Posted on Mar 25, 2007
I have an sony xplod 4 channel 600 watt amp
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
I have a 1200 watt sony xplod amp hooked up to a 15" SBL Gorilla sub. The bass hit for a while and then started to cut off. Now it wont work unless i touch the remote wire to the power wire, and even then...
this kind of problems usually happen when the amp is not getting enough current to power up the
 amp. the moment a loud low frequency hits the amp it fails. cud be ur power unit not giving enough power to the amp or u have a loose connection somewhere on ur power line. besides 8gauge is a bit small. try using about 4gauge. should have good ground too. they draw large current so ur battery should be in top condition as well.
Mar 21, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
I hooked this 1000 watt amp up.it turns on but it
Your amp needs to be serviced. Bad protection circuit. Take it to a local car audio shop and have them bench test it first to be sure. Hope this helps.
Sep 26, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Check the Polarity on the subs, you might have to invert one. Best way i know of to test is get a BASS CD -=download a bass test cd...legally of course=- and check for a test that will just flutter the speakers in and out and see if they both go in and out in the same way, if one is in and the other is out that could be your problem
Feb 02, 2007 | Sony XS-L122P5 Car Subwoofer
1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Jan 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Sony Xplod (P589) Car Subwoofer Logo
117 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
