D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
Reason code=1
I have a point to multi-point solution with the multi-point in WDS-AP mode and the clients in WDS mode. All 3 clients were up (for several years) until today.
One client failed this morning, and I replaced it. Two others were up, but after I put in the replacement, the other two went down with reason code=1. The replacement is up.
Security settings did not change on the multi or the two clients.
  • 1 more comment
  • maruthu Dec 25, 2008
    THU SEP 11 20:31:35 2008
    System
    --AP cold start with f/w version: v2.20e
    u
    Wireless
    --WLAN1 Normal AP ready
    THU SEP 11 20:31:40 2008
    Wireless
    --Received Deauth: WLAN 1 11A STA 00:15:
    00:4c:24:46 reason code=1
    THU SEP 11 20:31:54 2008
    Last message repeated 7 times
    Wireless
    THU SEP 11 20:32:01 2008
    Notice
    --Ethernet AE1 LINK DOWN
    THU SEP 11 20:32:11 2008
    Wireless
    --Association:11G STA 00:15:00:4c:24:46
    associated with WLAN1 SSID = 3rd Flr
    THU SEP 11 20:33:11 2008
    Notice
    --Ethernet AE1 LINK UP
    THU SEP 11 20:33:21 2008
    System
    --Web login success from 192.168.0.51
    THU SEP 11 20:34:11 2008
    Wireless
    --Received Disassoc: WLAN 1 11G STA 00:1
    5:00:4c:24:46
    THU SEP 11 20:34:24 2008
    Wireless
    --Deauth: WLAN1 11G STA 00:15:00:4c:24:4
    6 reason code=1
    Wireless
    --Received Deauth: WLAN 1 11G STA 00:15:
    THU SEP 11 20:35:35 2008
    Wireless
  • Anonymous Feb 01, 2009
    Feb 1 14:42:16
    Wireless system with Mac address 00:22:b0:c6:bc:5b deauthenticate reason 6
    Feb 1 14:42:16
    Wireless system with Mac address 00:22:b0:c6:bc:5b deauthenticate reason 8
  • Anonymous Feb 10, 2009
    Hi. Same problem here. Been working mostly very well for a couple of years, but the last several weeks, constant disassociation. I've tried everything, including realigning external antennas, cleaning all the antenna connectors, changing various settings on both units etc. etc. No solution yet. Maybe they only last a couple of years, and then wear out ?
    Problem Solver:
  • 17 Answers
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Posted on Apr 23, 2009
  • 3 Answers
Dear Sir,
I have to worked on the DLINK DWL-2100AP AS POINT TO POINT with WDS with AP AND second one WDS Without AP
(1) First Install the Router ADSL &Wimax (and check the internet)
(2) Second you are install the DWL 2100AP WITH Mode WDS with AP and connect with the another WDS take the Mac Address in the WDS With AP and WDS With AP take the MAC Address in the WDS AND it connect the router with the Lan cable With the WDS With AP
(3) Third you are configure the WDS on the second DWL-2100AP
(4) You remember that both WDS With AP and WDS Same SSID like DLINK and other one same SSID like DLINK
(5) Be Care full you are use the Same WAP \WEP like that same and Same PASSWORD
(6) When you are enter the net work in the wireless then you see only one DLINK
(7) I try this one it s fine the working
(8) If any trouble then send the mail I help you Thanks ghazanfarali_1@hotmail.com
Posted on Jun 21, 2010
I have d-link wireless access point,DWL-2100Ap, i need to setup my wireless connection,for 10 computers , what i can do?
Posted on Aug 11, 2009
Configurar modem dwl-2100 ap speedy
To configure the modem properly, you should refer to the user manual. It has all the settings detailed as well as a troubleshooting list:
Link DWL 2100AP user manual
Jun 24, 2012 | D-Link AirPlus Xtreme G DWL-2100AP...
Is there any limit for wireless D-link DWL-2100 AP ?
D-Link AirPlus Xtreme G DWL-2100AP Wireless Access Point provides speed upto 108Mbps, which is the maximum wireless signal rate derived from IEEE Standard 802.11g specifications. However, the actual speed depends upon the wireless network environment, setup and devices.
For further details please refer to DLink Official Product Description
Nov 26, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Getting 169.254...
possibly cat5 cable problem or your DWL - 2100AP is only on wireless mode.
please check and put on mixed mode also.
Mar 08, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
I have a dlink ap and i dont knoe wich firmare do i usse for make it multi user (im am using the ap client mode)
Ok 1s step
Your pc or laptop ip must be in the range of 192.168.0.100 to 192.168.0.200 so you have plenty of IP's to choose from.)
Ensure you have the correct DNS and gateway addresses assigned as well. Usually 255.255.255.0
SECOND STEP IS
TO TYPE THE IP IN YOUR BROWSER
HTTP://192.168.0.50
THEN BROWSE
USER NAME: Admin
Password: (leave it blank)
Nov 18, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
D-Link 2000AP+ and 2100AP Bridge configuration
Solution #1
Set the DWL2000AP+ as "Bridge Mode" and the new AP (DWL2100) in "WDS Mode".
On each device set the MAC address of the other device.
Solution #2
Set the DWL2100 as "WDS with AP Mode" and the DWL2000 in "Bridge Mode".
Aug 31, 2009 | D-Link : DWL-2100AP Wireless-G 108Mbps...
No super g, no turbo
Super G is if you have a Super G card or speed boost is what they call it. You have to have a Speed bust wireless card for this feature to work. You should just upgrade to wilress N you be glad you did and it will be much cheaper in the long run.
Jul 17, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
AP does not work in Repeating Mode?
check your wi fi is enabled on ap settigns also che k broad cast ssid is enabled on it.
Apr 27, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
DLINK DWL-2100AP
check whether DHCP is enable on ur main AP.
Apr 21, 2009 | Computers & Internet
Dwl 2100ap
This is the power cycle of death. No way to recover at this point. Send in for repair.
Jan 28, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
DWL-2100AP
To use the DWL-2100AP as an access point (repeater), You have to set it up on the repeater mode and type in the MAC address of the router. The best way to do this is to run the AP manager from the cd.
Here is a link to the D-Link support page. Click on product manual from under the Support resources
http://www.dlink.com/products/?pid=292:
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 25, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Computers & Internet Logo
14,725 people viewed this question
David Payne
David Payne
