Question about Hitachi FDX Series 43FDX10B 43" Rear Projection Television
My picture just started having doubleimage like shadowing
Predominately blue and yellow in color. I have a rear projection hitachi
  • 1 more comment
  • jelance Dec 07, 2008
    I have severe double imaging on my screen. Please provide a solution.
  • calhunter Jan 01, 2009
    I have severe double imaging on my screen. Please provide a solution. Looks like gun alignment. How can I re-converge since the "Magic Focus" has rtun out of tricks. It appears to be the blue gun primarily at fault.
  • meisner1207 Apr 29, 2009
    i have a 2002 hitachi ultravision hd projection tv. everything works
    except the pic has a blurred double image. i've been told it could be a
    convergance problem. and it would cost about $200 to fix it. if that is
    the case would it even be worth fixing? i just don't want to take it
    some place and get screwed cause i'm a female.
  • 42 Answers
T
your convergence ic's are Shorted
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
Posted on Feb 10, 2009
The top of the screen is yellow color then drops down in a swoop and more yellow and blue. otherwise picture is good, pushed the magic focus but it did no good. thanks for any help
The magic focus button don't work.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
PICTURE HAS BLUE SHADOWS AND YELLOW SHADOWS
This is a problem with the color weel wich is located in the light engine most of the time tiu need to check out the model numbers to check this out
Jan 26, 2010 | Hitachi 60V500 60" Rear Projection...
Picture has shadows with different colors (red, yellow, green)
Sounds like the convergence needs adjustment. You can do this through the menu-follow the on screen instructions. The idea is to line up the red, green, & blue.
Jun 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 46F500
Having yellow and blue shadows outlines show up on picture.
Oct 03, 2008 | Hitachi 46F500 46" Rear Projection...
Red color not lined up
You can try making adjustments to the convergence in the user menu. If they still will not line up you will need to have the convergence ICs replaces along with a few resistors in the convergence circuit. Fairly common in many rear projection TVs.
Sep 11, 2008 | Hitachi 57F500 57" Rear Projection...
Blue and Yellow shadows
Google "HItachi Convergence Circuit" and you will see that it is a very common problem. Looks like TV repair guys get $400 to fix it. The parts will set you back $15-$50 but there is some complicated soldering to do.
I am going to repair my own...but I have a lot of experience in soldering
May 05, 2008 | Hitachi 50GX30B 50". Rear Projection...
Hitachi53SDX89B color problem
Blue convergence IC bad...have both IC's changed..insist on
STK394-160E upgrade part # CZ 01341 Hitachi brand.....Original part is STK392-110......Also, check B+ feed resistors next to
convergence amp IC's for burn / damage...after rebuild, press magic focus.......................T.
Dec 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Blue and yellow shadows
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 15, 2007 | Hitachi 60FX20B 60" Rear Projection...
Hitachi FDX Series 43FDX10B 43" Rear Projection Television Logo
222 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
