Question about Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Low volume when volume control turned all the way up
I have the volume on the TV and the volume on the satelite box tuned to the maximum and I still have low volume.
  • 1 more comment
  • gravityfeede Dec 27, 2008
    I have a friend with the same problem. Have you been able to solve why the TV volume is so low? His TV is also a Sharp.
    Stefan
  • Anonymous Jan 04, 2009
    Same problem. Volume is all the way up and I can barely hear it. :)
  • Anonymous Feb 20, 2009
    Im having the same problem but with the new DTV boxes. . .What do we do??
I just had the same problem. Unplug the both the TV and the cable box for 5 minutes.
Posted on Mar 01, 2009
Error message on screen that says PO 1.15 V100
The error is likely to be from the satellite as the set model listed does not have that kind of error.
Nov 29, 2012 | RCA P52926 52" Rear Projection Television
Problems with volume
You need to turn up the volume on you fios box it has a seperate volume control. The volume needs to be fixed on the box versus variable to stop this from happeneing.
Josh
Feb 29, 2008 | Televison & Video
No volume sound very low at maximum
Look both at the set and the Box if used (cable or sat) to make sure volume is not turned down---also a receiver if used can do the same thing.
A quick low tech test is do you have the same problem when playing a DVD etc.
Apr 24, 2012 | LG 42LC2D 42 in. LCD HDTV
I just recently got directv installed and ever since my volume on my sansui tv turn down by itself any idea why
Hi:
Most cable or satelite boxs have their own volume controls try using the boxs remote to change vol levels to see it this solves your problem.
May 22, 2011 | Televison & Video
We bought Toshiba Regza LCD 40CV700E, last month and from the time we started using it the maximum volume is very low compared to other tv's. I have called the dealer and after the assistance given by them...
Take the people adviced exchanged it for another tv,this tv 100% have it main tv Tuner signal board have problems,that the most important board for the tv,beside the tv LCD screen panel itself.
Apr 30, 2011 | Televison & Video
How do you tune in tv channels when you only have a signal input from a satelite dish and no sky decoder. TV is a sharp lc-32l400x with built in freeview. Can we plug dish straight into TV aerial port...
You require a satelite decoder/receiver for your dish and an aerial for your TV.
The choice is yours. Plug a satelite receiver, for freesat, into the A/V input on the TV or have an aerial installed for freeview.
Jan 19, 2011 | Televison & Video
Sharp 32c231 volume too low
If you are using a cable box with this set, the problem may be in the box settings.
Try this:
open the settings menu on the box . You may have to select"more settings" or something like that title to find the audio selections.
Under the audio, you will find recording and viewing volume settings. put these to maximum and save.
Your volume should now be more than adequate.
May 03, 2009 | Sharp 32C-240 32" TV
I recently hooked up my dtv box, tuned the antenna and have a great picture. On every channel I have background noise. Sounds like bacon frying, hissing noise. I also set up someone else's tv, very simple....
If there is a volume control on the remote that came with the converter box, use it to make sure the box volume is set to its maximum. Many models allow you to control the volume out from the box to the TV, and the levels are set about halfway. When you turn up the volume on the TV cause it's too low, you can get the kind of audio problem you describe. Make sure you turn the volume down on the TV first before starting with the box.
Feb 18, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Maximum volume on the set is too low!
On some cable boxes they have their own volume control. Raise the volume on the box if you can. if the volume on the tv is up all the way it should be loud. It should not be the tv if you have volume already coming out. try hooking up a dvd player or some other device and see if you have the same result
Aug 06, 2008 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Sharp 27DV-S100 27 in. TV/VCR/DVD Combo Logo
935 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
